IMAP set up in Outlook
John_Hull
Hi
I've just got a new laptop, and I'm setting up my email again. I've never had an issue with getting Outlook to open with my FOL mailbox, but for some reason I can't get it to do it this time. The mailbox works OK, (I think the settings came across when the new laptop pulled over a backup of my old machine), but when I start up Classic Outlook, it defaults to a school  governor mail box on an exchange server, and it won't let me change the default to the IMAP FOL account.
What am I doing wrong?
4 REPLIES 4
redsox9
Fixes: 4
Re: IMAP set up in Outlook
Have you tried to configure Outlook through Control Panel -->Mail?  Changes made here tend to stick.
John_Hull
Yes. it comes up exactly the same. The suggestion is to disable the exchange cache, but none of the ways of doing that that Google throws up matches what I can see.
John_Hull
Found what I needed!, I ignored all the advice on line and started from scratch.
File - Options- Advanced-Outlook start and exit
Seems obvious once you've found it 😒
Thanks for your help.
redsox9
Fixes: 4
Most things are obvious once found.🤗
