Unknown Sender errors from Greenby
mavison
Since our migration in December to Greenby the three Force9 email accounts for myself and my sone have worked, though not without some problems.
However, in the last week or so one son and myself have had problems sending some emails, as they have failed with 'Unknown Sender'. We all use @account.f9.co.uk addresses, not @account.force9.co.uk.
Greenby are now claiming that in order to send an email from eg [email protected] then name must either be the name of the mailbox, or have an alias for that name, and this has been the case since migration. This applies even to a catch-all mailbox.
My suspicion is that this was NOT the case until a week or so ago, and something has changed recently at Greenby.
It certainly was not a requirement of the Plusnet/Force9 email system.
Has anyone else had recent problems with Unknown Sender errors from Greenby?
15 REPLIES 15
balvack2
Re: Unknown Sender errors from Greenby
Hi @mavison I'm still waiting for PN support to get back to me on why I can't send from my "mydomain.co.uk" identity in webmail which worked fine for a decade prior to migration. Given the feedback you were given I'm going to try and set up an alias, but I've gone through all the webmail settings and can't see how to do that. Could you advise? thanks
mavison
@balvack2
Create an alias by signing on to greenby.com.
Under Recent Products, click on Manage against your email domain to list all your mailboxes.
At the right of the line for the mailbox, click on the 3 dots to open a menu.
Then click on Aliases, and add the alias address you want to send from.
Fixes: 583
@balvack2
Is this domain hosted by Plusnet ? or is it just a personal domain registered elsewhere ?
balvack2
@MisterW
It's a personal domain registered elsewhere. The 'identity' worked fine on webmail pre-migration. Leanne has looking into it but I guess she's been busy with all the other issues.
balvack2
thanks @mavison but that only lets me create an alias with a myplusaccount.plus.com suffix, not mydomain.co.uk
Fixes: 583
@balvack2
Thanks, that's what I suspected.
I would suggest that you arrange for the domain to be properly hosted and use the hosting servers to send mail. Being able to send from a domain address via the PLusnet servers in the past was really a loophole. I'd be pretty sure that the Greenby servers (like most others) dont have that loophole.
I'd suggest looking at Mythic beasts for hosting https://www.mythic-beasts.com/order/hosting?product=H-050
a basic Email account will only cost £20/yr
balvack2
My domain is "properly" hosted. I can still send from my mail client OK, it's just the functionality in Webmail that has stopped working since the move to Greenby.
After more than a couple of decades with plusnet it looks like I'm going to have to bite the bullet and migrate our numerous mailboxes elsewhere. I'm certainly not going to pay £15/year to Greenby for a mail system that has reduced functionality and no customer support.
Fixes: 583
so are you saying your domain is hosted by Plusnet ? I thought you said it was registered elsewhere ? It's been a very long time since it was possible to have a domain on a Plusnet account as 'hosting only'
AFAIK no accounts with hosted domains have been migrated
I suspect you can send from an email client because relay.plus.net is (temporarily) still routed directly to the Plusnet server, whereas webmail will route a  migrated account to the Greenby server. Once the temporary situation is rectified, you won't be able to send from a client either
balvack2
@MisterW
It's not hosted by Plusnet: it's hosted / registered elsewhere with email forwarding setup for about 10 mailboxes so [email protected] goes to [email protected]
It's really worrying that you say that it's only temporarily still working on my mail client. When is that temporary period going to end?
I guess that's the incentive for me to finally get sorted with moving my email elsewhere....
Fixes: 583
@balvack2
Sounds like your domain registar only provides a basic email forwarding service. If they provided a true hosting service then you'd be sending using their smtp servers.
I dont have that detailed information. All I can say is that the plan was for all access, for both sending and receiving, to go via the Greenby proxy in order to make migration as transparent as possible for users. My understanding is that for technical reasons relay.plus.net is not currently routed via the proxy but will be, as soon as possible.
balvack2
@MisterW
I've delved into my domain hosting setup and found that a long time ago I'd added this TXT entry to the DNS configuration. If I recall it was to permit outgoing (?) email to come from plusnet via my domain.
v=spf1 include:_spf-internal.plus.net include:_spf-internal2.plus.net include:secureserver.net -all
Would adding an additional record for whatever the Greenby equivalent is allow me to continue sending from my mail client as I do at present before relay.plus.net gets re-routed through the proxy?
Fixes: 583
@balvack2
An SPF record doesnt actually permit sending of mail, it just means that mail received from your domain via those servers is to be treated as authorised.
No. Most email providers will only allow mail to be sent from domains that are hosted by them. As I said earlier , the Plusnet servers had a loophole that would permit mail to be sent from any domain. The Greenby servers will only allow mail from domains that they actually host.
balvack2
thanks for the clarification @MisterW
I set it up so long ago I couldn't remember why it was needed....
Fixes: 583
@balvack2 if you've got as many as 10 mailboxes, then I'd look at Mythic Beasts for email hosting. You can have unlimited mailboxes, aliases subject to a total 2GB space on their mail only product. Some other hosts charge on a per mailbox rate so can work out expensive with many mailboxes.
