Emails to btinternet addresses being blocked
Simon109
My emails to btinternet addresses are being blocked/not received by addressee and returned as suspected SPAM. How to fix please?Huh
21 REPLIES 21
spsmiler
Re: Emails to btinternet addresses being blocked
I had the same problem when sending an email to someone with an @outlook.com email address.
A few hours later it cleared itself.
Its a mystery as to why, but I am happy that it did.
Simon109
I have now found out that these problems are all to do with Plusnet email transferring to "Greenby" and can't be fixed until that is completed. Meanwhile I will have to use Gmail instead!
Moderator's note:
Fix removed
stuck
Who told you that?  From other topics about Plusnet messages being blocked on this forum, it seems to me that it's got nothing to do with the migration and everything to do with parts of Plusnet's email network being blacklisted.  Such blacklisting can be, and is being fixed. Having said that, it does feel like that as fast as one block is lifted another one comes down.
Simon109
Been told by Plusnet "Help" that there's nothing that they can do as it's all now gone to Greenly, so just got to wait until the transfer is complete and that the blacklisting gets solved!? Meanwhile use something else, e.g. gmail.
Fixes: 334
@Simon109 Don't believe what PN first-line support tell you about the mail service - they have no training/guidance on it as it is being transferred to Greenby.
Is your email address a 'plus.com' one, or one of the legacy brands?
Simon109
Yes it's .plus.com and appears to be blacklisted by btinternet
Fixes: 334
What error messages/NDRs are you receiving?
Simon109
Fixes: 125
@Simon109
I doubt that image will be released as it contains personal information.
Fixes: 334
Cheers, @Dan_the_Van - does it give us any clues as to the possible issue, though?
Fixes: 125
There are a few email addresses which may not want to be public.
I note this message
HTH
Edit: It seems me downloading the image approved it to be published, I have had to set the image for approval to remove it from being public. @Simon109 sorry about that
Fixes: 334
Thanks, Dan. Suggests some 'content' has been classed as 'spammy'?
Simon109
Even an email that just says "Test" has been blocked!
Fixes: 334
Your BTinternet customer needs to talk to them, but note the service is actually provided by 'Yahoo', who have some strange ideas.
