Deleting emails with webmail
MuttlyD
I have had the dreaded email saying reduce your mailbox size. But Webmail never works, hanging or saying connection times out. Even when it does it takes ages to delete only a minimal amount.
What's the answer to this truly annoying problem.
Come on plusmail give us a decent service as it should be really quick and easy
Mark
6 REPLIES 6
Fixes: 387
Re: Deleting emails with webmail
@MuttlyD How much is in your inbox/sent/deleted folders? Are trying this on a computer or phone/tablet?
As I don't use webmail, I can only give you limited advice - but one thing I remember from someone with more knowledge than me on this is to set the 'sort' order to 'none'.
MuttlyD
Mailboxes are 430Mb. Have tried it on both tablet and laptop subsequently.
Will see if I can find sort order option.
Don't mind having to have tidy up, just be nice for the tools to work
Fixes: 387
When logging in, try the 'basic webmail' option on the login screen. The 'sort order is under the little box with a down arrow, extreme left of the inbox.
archerry
Fixes: 4
@MuttlyD
I think the thread @jab1  was thinking of is this one:
https://community.plus.net/t5/Email/StandJohnard-Webmail-Round-Cube-slow-performance-mitigation/m-p/...
Edit
John is quicker than me.
And I think the " nearly instantly" is rather optimistic these days.
Fixes: 387
Cheers, @archerry  - it was - forgot Townman had kindly put that up.
Fixes: 250
Why use webmail?
Most device based IMAP email clients will give you a far better experience. That said, do avoid “new” outlook.
