Android phone mail set up problems ... what are correct settings ?
Mccarthney
I have replaced my phone but cannot add my plus net email and keep receiving user name / password error or Imap not recognised messages.
Post migration have settings changed? My tablet and other android phone work ginger bug my new phone judg won't accept my user name and imap settings?
11 REPLIES 11
PhilipHeyes
Champion
Fixes: 19
Re: Android phone mail set up problems ... what are correct settings ?
Username is : email address i.e avoid using <account>+<name> or an alias
Server : imap.plus.net
Port : 993
Encryption : SSL/TLS
Mccarthney
Thanks I did change my user name config from Account+ name to use full email address.
However, I am still getting the message "couldn't verify account - the username or password is incorrect or pop3 / IMAP access isnt turned on for this account. It is asking to check and try again which I have. I am receiving emails but cannot send?
I have never had issues with plusnet mail until Greeby transition and wondered if there is any change to config required now which will fix email settings ?
Bit frustrating as a customer of plus net for 26 years plus
Fixes: 582
Have you got 'outgoing server requires authentication' selected ? use the same username/password as for incoming
Mccarthney
I have outgoing server authentication already selected but it wont send and holds mail in outbox.
I've tried both relay.plus.net and smpt.plus.net
Fixes: 582
Do you still have a Plusnet broadband account ?
If not , then change the outgoing server to mail.enmail.co
Mccarthney
I do still have my Plus net broadband.
I have been awaiting an upgrade to high speed fibre which was partially installed internally on the 11th June but has yet to be connected to the poles outside so still running on copper.
It is about this time Mid June i stated to suspect issues with my settings ? a co-incidence do you think? or should i contact Support ?
Fixes: 582
Since you still have a PLusnet account, relay.plus.net is correct for the outgoing server , use port 587 and STARTTLS
If that's the case, then it would seem to be a problem with the configuration on the new phone.
Mccarthney
As a test i set up a new mail box and password on Greenby site/ settings then attempted to set up outlook and samsung mailbox in Android as follows:
email
password
imap.plus.net
username (full email address not Username+ mailbox name)
port 993
StartTLS
relay.plus.net
Username - full email
Password
port 587
start TLS
I then submit and  receive message logon unsuccessful "[IMAP] a stable connection to the server could not be established"
Fixes: 582
The incoming (IMAP) connection should be SSL/TLS not StartTLS
Mccarthney
Thank you for the support the change of configuration has allowed me to set up a new emails address However, I am still unable to send emails via the email that i had set up on my new android phone. I receive messages but cannot send they sit in the outbox. I have tried outlook Gmail and Samsung mail to see if the issue was with the App(s) but none of them connect and give the same 'unable to connect' message.
Is this something related to transfer to Greenby that i can fix and adjust a setting or is this an android issue ? or simply me getting the config of the settings which were : username+ email but now are : [email protected] / [email protected] / imap.plus.net and relay.plus.net completely wrong?
Thanks  for the support Smiley
Fixes: 582
@Mccarthney
If this is a new mailbox that you've setup from a Greenby account, then try changing the outgoing server to mail.enmail.co .
In theory, relay.plus.net should still work since all connections SHOULD go via the Greenby proxy which will be aware of any new mailboxes or password changes made on the Greenby portal. However,  for various reasons, relay.plus.net is temporarily direct to the Plusnet servers, so it will not know about any such changes. mail.enmail.co is the Greenby mail server and so should be aware of the changes.
