Accessing my Freenetname mails in Outlook
howard
Hi
I have a Freenetname/Madasafish email account.  For years, I've had it, and a couple of other email accounts (gmail, yahoo) added to Outlook.  Recently, delivery of my Freenetname mails to Outlook became sporadic.  In the last few days, it's stopped completely.  I can still access the mails by logging into my Madasfish webmail but I'd really prefer to have all my mails from various accounts in one place.
In Outlook, I tried several times to sync the freenetname account.  Each time it said that it couldn't make contact with the server.  In the end, I deleted the account from Outlook and tried to re-create it.  At that point, I realised that I don't know what settings I need!
So, the question is "In Outlook, how do I add and configure an account that will receive mails sent to my Freenetname account?
14 REPLIES 14
adam945
Fixes: 113
Re: Accessing my Freenetname mails in Outlook
Hello @howard
Thanks a lot for getting in touch and I'm sorry to hear that you're having issues with your freenetname account. The settings you'd need are as follows:
Incoming server - mail.freenetname.co.uk
Port 110 for POP3, and Port 143 for IMAP.
Outgoing server (SMTP) -smtpmail.freenetname.co.uk
Port 25 or 587.
 Adam
 Plusnet Help Team - Leeds
howard
Hi Adam
Thanks.  I tried the IMAP settings first.  They returned error "We were unable to reach your email provider.  Please check your server settings, or try again later." That's the error I've had previously.
I then tried the POP3 settings.  This time I get "TLS negotiation failed with status "InvalidToken".
For both IMAP and POP3 I tried both outgoing SMTP port numbers, with the same result.
Any ideas?
Howard
PS. I just tried setting it up on my phone.  It asks me for POP3 username and password and SMTP username and password.  I'm not prompted for those when I try to set it up via my online Outlook account.
adam945
Fixes: 113
Thanks for getting back to me @howard
I've just refreshed and reconfigured the components on our side, give it another go when you can and let me know how you get on. Smiley
 Adam
howard
@adam945 I've tried several times over the last couple of days, but still no luck I'm afraid.
Fixes: 240
The information provided above is not appropriate for encrypted (TLS) connections.
For encrypted connections you need...
  • IMAP Port 993 with SSL/TLS
  • POP3 Port 995 with SSL/TLS
  • SMTP Port 587 with STARTTLS
You also need to check that the server names are correct - Outlook guesses at server names and invariably gets them wrong.  You need to configure them manually.
LaurenB
Fixes: 131
Hiya @howard, thanks for getting back to us. I would advise to follow @Townman advice and let us know how that goes.
 Lauren Barry
howard
Still no luck.  With those port numbers, I no longer get the TLS error, but I get "Unable to reach your email provider..."
In Outlook live, there's no option to select StartTLS.
If I try in the Outlook app on my phone, I do get the StartTLS option, but I'm also asked for a POP3 and SMTP username and password.
I worry that we might be getting into the realms of user error 😟
See attached.
LaurenB
Fixes: 131
Thanks for getting back to us, for the authentication type can you please advise what other options it gives you?
Have you been able to get any success when entering your username and password on Outlook on your phone?
 Lauren Barry
howard
@LaurenB Here you go:
On the Outlook app, here are the fields and options (it wouldn’t let me screen grab it because of security policy 😞 )
  • Email address: I’ve inserted [my_userid]@freenetname.co.uk
  • Display name
  • Description
  • POP Host Name and Port (POP Incoming Email Server0. Options are:
    1. SSL/TLS
    2. Start Tls,
    3. None
  • POP Username: No idea
  • POP Password: No idea
  • SMTP Host Name and Port (SMTP Outgoing Mail Server).  Options are:
    1. SSL/TLS
    2. Start Tls,
    3. None
  • SMTP Username: No idea
  • SMTP Password: No idea
On Outlook.live.com, these are the fields and options:
  • Display name
  • Email address
  • Username
  • Password
  • Choose your connection type:
  1. IMAP/SMTP connection settings
  2. POP/SMTP connection settings: This is the one I’m selecting
  3. SMTP send-only connection settings
  • Incoming (POP) server
  • Incoming server port (defaults to 995)
  • Leave a copy of messages on the server: checked
  • Authentication:
  1. Basic
  2. SPA
  • Encryption
  1. SSL
  2. TLS
  3. None
  • Outgoing (SMTP) server
  • Outgoing server port: defaults to 587
  • Use different username and password to send mails: Unchecked
Fixes: 240
The first thing which jumps out is “no idea” to the key bits of data - user name and password.
It is not enough to specify just the email address, you need to supply the user NAME as well which might well be the same as the email address.
howard
Ah, I should have mentioned that I'd tried that already. Because it didn't work, I assumed it needed some other user id and password.
Anyway, I started again on my phone. This time, the POP and SMTP server fields auto- filled with plusnet server names, rather than freenetname. Having put in my username and password, it works!
Anoush
Aspiring Hero
Fixes: 139
Hi @howard
I’ve taken a look at this for you and as I’ve been typing, it looks like you’ve figured out the issue and sorted it Cheesy
The Freenetname (or Madasafish in general) e-mail servers don’t support secure authentication, so you won’t be able to use SSL/TLS or STARTTLS, however you can though use the Plusnet servers which do support this, those settings are Here.
If you select none/basic authentication, you should be able to setup your emails using the details Adam’s given, but I’d recommend using the Plusnet servers. Smiley
Let us know if you need any further help.
This is my personal Community Forum account to help out around these parts while I'm at home. If I'm posting from the 1st March 2020, this means I'm off-duty with no access to internal systems.
howard
@Anoush @Townman @LaurenB @adam945 Well, "figured it out" is probably putting it a bit strongly, but we got there in the end!  Thanks all.
adam945
Fixes: 113
Glad to see that it's sorted @howard
Give us a nudge if you need any further support at all. Smiley
 Adam
