What Makes a Veteran
FIXED- Subscribe to RSS Feed
- Feedback
- Community Site Feedback
- Re: What Makes a Veteran
on 09-04-2016 12:38 PM - last edited on 09-04-2016 1:35 PM by Strat
What makes a veteran a veteran? Length of membership? Number of posts? Some setting that was in SMF that was used to identify Bright Sparks that's been carried over?
I ask because I've been struck down with the label and animation ![]()
F9 ADSL customer since 2004
F9 FTTP customer since 2024
Fixed! Go to the fix.
on 09-04-2016 12:45 PM - last edited on 09-04-2016 1:53 PM by Strat
Longevity & Post count are certainly the main factors. The comment has already been made to Plusnet that there are some not too happy with this - got a suggestion of a rank you'd prefer. Chris Parr suggested in the Veteran's post in Chit-Chat that it could just be removed and you'll progress up the ranks with others. The Bright Sparks logo should not have been applied and that has also been commented on.
Moderators Note. Posts split off bugs thread and renamed.
09-04-2016 1:38 PM
I assumed they analysed all your previous posts and if you appeared mostly old and grumpy...
09-04-2016 1:43 PM
And especially 'grumpy' ![]()
09-04-2016 2:30 PM
And what for that matter is a "Grafter", I'm sure I was a "Bright Spark" before so is that the new equivalent?
09-04-2016 2:36 PM
You were, and you should be a Community Veteran now. I personally haven't had a moment to check around for these things, but as I said above, it's been poorly implemented and you've obviously been missed out
That should be remedied.
09-04-2016 2:40 PM
@HPsauce Grafter is one of the standard ranks. It's possible you were missed when the Veteran roles were being assigned, but I've flagged this up to be looked in to. Should have more info on that next week for you.
09-04-2016 2:42 PM - edited 09-04-2016 2:43 PM
Talking of "brigt sparks".... I notice that quite a few of us have that "bright spark" thing running against our name of Community Veteran... now... ? ? ? ? Is that another bug or what ?
09-04-2016 2:43 PM
09-04-2016 2:45 PM - edited 09-04-2016 2:47 PM
OOoooh.... so now I can be a "Grumpy Old Bright Spark Git Veteran" ! !! ... ![]()
Or... other versions ... Grumpy Old Veteran Bright Spark Git ......
Grumpy Veteran Old Bright Spark Git.
Veteran Grumpy Old Bright Spark Git..
09-04-2016 2:46 PM - edited 09-04-2016 2:46 PM
@HarryB it needs to be removed because of the bug(s) it's introduced as I remarked in the bug thread. I've also commented in another place ![]()
09-04-2016 2:48 PM
Thanks Harry, no rush whatsoever. I've been largely out of circulation for a while with other priorities so am only dropping by occasionally at present.
Hopefully I'll be back more constructively soon, though with the forum in its current state I do wonder......... ![]()
09-04-2016 3:14 PM
So what does make a "Veteran"? Is it the number of posts or the length of service?
I'm only a "Grafter" but have been around since October 2007. I read a lot of the posts but have only made 111 (now). All seems a bit random...
09-04-2016 3:17 PM
09-04-2016 3:34 PM
Well I've dropped from UserGroup member to Grafter after lots of posts under a previous username - (mauriceb - abandoned after a problem in the old forum). Never been too fazed by titles though![]()
