Slow, sluggish and buggy?
- Feedback
- Community Site Feedback
- Slow, sluggish and buggy?
04-08-2011 8:35 PM
Anyone else having any issues when posting on the forums?
Quite often i spend quite a good bit of time writing, (not noticing that the page hasnt finished loading something not required) then when the page does finish (2-3 mins later) the text box resets... =
I hit "POST" and theres a massive delay (page does nothing, displays loading as normal...) this doesnt happen *every* time, but it happens probably once in every 4 posts. If i hit "preview" the preview loads instantly, then the post button will work again (repeated smacking of post actually just makes it do nothing) Normally, i end up ctrl+a, ctrl+c quickly before the page times out (i norm give it a good 40 secs to post..) hit the breadcrumb link at the top, then join the back of the topic, reply, paste, instant post
stupidly long loading times (post page has been submitted, and then the page crawls back).
Currently using IE9/Win7 x64 with acceleration on in ie9
and yes, it happens in FF before someone blames microsoft
my FF is a "clean" setup (every time it closes it deletes *everything* so i dont think its a cookies/cache problem)
Any suggests / people experiencing similar is very welcome, i feel a little excluded currently
Regards
^^ just done, bit more sluggish than im used to but should be more than ample for forum software
Note, it happens when editing posts too - as its taken me now 4 times to do a simple edit 😛
Re: Slow, sluggish and buggy?
04-08-2011 9:25 PM
And you can imagine how difficult it makes moderating.
Also uploading a small picture takes for ever
04-08-2011 9:51 PM
I thought i was going insane!
Hats off to the staff and mods who are putting up with it
My recent flow of posts might be coming to an abrupt end... heh
Regards
04-08-2011 10:22 PM
How about deleting the whole thread to see if it helps
04-08-2011 10:44 PM
Shouldn't make a difference Jim, seen hundreds of sites use many many threads much longer (particularly complaints threads on companies like Codemasters..)
More than likely because the community servers are under much more load and the kit isnt up to it, or a slight hardware wobble (HDD maxing out I/O or is on the way out?)
But then, idk how PN is load balancing community, other than i know its on a different server (farm?) to the portal
Regards
05-08-2011 12:51 AM
edit: bah never noticed it does have that option, maybe try that and see if it helps
05-08-2011 1:28 AM
But although its worse, i dont think thats the cause, looks more like communities issue, rather than stuff on the site (does it on new topics too, so theres no pictures n stuff...
Regards
05-08-2011 9:20 AM
Uploading pictures is just fine - I can see from the NetWorX monitor it maxes out my upload.
I'm on Max Premium with a solid 7616*/832 sync and I have the Pro add-on.
*Hold on, where's my full speed sync gone? Why has interleaving been turned on on my line?
05-08-2011 9:39 AM
Personally its just the problems i listed originally. (no issues with images on teh forums)
when the pages load, they're instant, just seems to sit there doing sweet FA every now n then...
Quote does it on new topics too
Text only comment, and just my sig (just text) - so no major issues - site related or somethings hinky with either my laptop, or my connection.
Regards
05-08-2011 9:45 AM
This picture uploaded at full speed but then the forum sat there for about 15 secs before posting
05-08-2011 9:53 AM
Quote from: Matt_2k34 when the pages load, they're instant, just seems to sit there doing sweet FA every now n then...
Now that I do see. Click on a topic and it does sweet FA, click the link again an it's there at normal speed. But no way would I call it sluggish which implies it is constantly slow.
05-08-2011 10:01 AM
Bursty, Sluggish in certain operations and generally unreliable. as i said before ive often had to "repost" my reply, because the page refuses to progress, so i have to copy my text out, reload the page tand then start over.
Regards
05-08-2011 11:55 AM
Would be really helpful if you guys spot any patterns here, i.e. certain times of day, certain sorts of action etc.
Ex-Plusnet Jobsbody
05-08-2011 12:22 PM
You'll have to be abit more active Kelly, and see if you can spot anything too
Regards
05-08-2011 12:37 PM
Why has my line been changed to interleaved?
Pain at the Pump
ADSL2+ Rejected by BT
all farely new topics (within 50 topics of each other :P) its just taken me 6 attempts to put a post on the first link. Joke
Regards
