Search/Own Posts
Razer
Search/Own Posts
There doesn't seem to be a feature with the forum to search for threads started by self/other. Neither does there appear to be any link in my profile to look at threads I have started (only a list of ALL posts). Am I missing something?
9 REPLIES 9
Oldjim
Resting Legend
Fixes: 63
Re: Search/Own Posts
You aren't - it is very unfriendly from that point of view
I find it easier to use google and then search for
    "community.plus.net"  +  your username  +  search keyword(s)
Razer
OK, thanks Jim. Another reason for PN to switch the crappy forum software for something which can do a better job (like vBulletin).
@purleigh. Which is just the same as the forum software can do. It won't give only threads started by username, but all posts with the keyword.
alanf
It is possible to obtain a list of all recent (and not so recent?) posts someone has made by clicking on their name to the left of any post that they have made.
I realise that a) this is all posts and not just threads started b) as far as I am aware there is no was to refine this to return posts containing only specified keywords.
Quote from: Razer
In Profile Search posts, ignore any results starting with Re:
Not ideal though.
Or...
For your own threads started...
Assuming you have not Unsubscribed from any threads you started, view Notifications and emails, this does give a list of all subscribed threads, but includes any you started, and are still subscribed to..
Also... in your Stats, 2nd Pic
The Best Solution .....   Google         "topic started by [color=red]razer" site:community.plus.net[/color]
Insert user name here
Razer
Ignoring those with 'Re:' - That's what I did. Long and laborious.
As to searching "topic started by razer" etc. I'll give that a try, assuming google robot does monitor those pages. Thanks for that.
It does work, though the final "print" format is a bit different, there's probably a Boolean expression to get round that .
Examples...
Google   "topic started by razer" site:community.plus.net -print page
Does sort of get you round that, though the result is that you appear on a page of main subject headings, not an individual result.
"Find" would take you to your threads.
Razer
Thanks very much PC, I appreciate it. It does the job.
