How come no 'Join Date' ?
Cagney1994
Hi all
I was quite surprised there's no join date when you sign up  Shocked
Can this be added on ?
Thanks.
2 REPLIES 2
Oldjim
Resting Legend
Fixes: 63
Re: How come no 'Join Date' ?
Click on Profile in the top menu or just click on your username
Shows date registered on the forum
However if you are referring to the date you joined Plusnet that is confidential and therefore isn't included in the Forum information
Cagney1994
Thank OJ.
And the join date I was referring to usually appears under your username (on other forums). As mentioned, a bit surprising it's not there but hey, if that's the way it is, then who am I to say otherwise ? Smiley
