Ranking system going crazy?
Strat
Fixes: 565
Re: Ranking system going crazy?
@rongtw You might want to screen-shot it for posterity.
198kHz
Fixes: 42
BT technician (Retired)
Jonpe
Fixes: 9
Thirteen hours ago I became Champion, Seasoned Champion, Aspiring Legend, Legend, and Legend (yes, Legend twice).  It seems that apart form Moderators and PN staff we are all Legends.  At first I thought it might be a virus at work, but if it was North Korean someone like Gandalf would be Great Leader and the rest of us Comrades.
Fixes: 244
Some of us remain mere veterans!
Mustrum
Fixes: 81
Maybe cos we are not on the Super User Program - ooops, did I say something I should not have ? 😉
Fixes: 244
That programme is not yet implemented.
198kHz
Fixes: 42
Seriously though - is there any mileage in the fact that, as far as I can see, the only ranks to have remained the same are ones beginning with 'Community'.
Mustrum
Fixes: 81
You reckon!
Fixes: 244
Super user - yes I recon.
The ranks which have remains static are the ones which are assigned manually rather than calculated.
I see that a new (spamming) member from this morning is already a legend! I thought this had been disabled? @jaread83
MauriceC
Resting Legend
Fixes: 17
Don't you just get to love the Lithium QA testing regime.Evil
With open arms @MauriceC, but I'm of the opinion that new registrations should be disabled until this is resolved the longer it goes on the more tidying up will need to be done.
Multi-edit, sorry.
jaread83
Fixes: 81
We can't disable new registrations as then it would block legitimate customers wanting to get help. I am aware that new users are being granted the 'Legend' rank. I have removed the permission roles granted for the higher ranks so this should make no difference to how users interact with the forums.
We are waiting for a solution from Lithium right now. Louisa got in touch with senior staff and it has effectively been raised in severity to be looked into as a matter of urgency (similar to if the entire site was to go offline). We have received word that it is being looked into and a solution put in place asap.
I will keep you all updated as and when I get any information about whats happening.
jaread83
Fixes: 81
That is just a coincidence. The mods, admins, veterans, superusers and a couple of others are all regarded as assigned ranks - the only way to get those particular ranks is if you are assigned them by an admin. The problem seems to lie in the ranks that can be earned through posts, likes/thanks and length of time since registering.
nadger
I'm a superuser on NowTV forum and my rank has suddenly changed to Rupert Murdoch Roll_eyes
