Priority - Forum bugs have appeared
Anotherone
Champion
Fixes: 21
@mtrinder @Chris @bobpullen
Several bugs have appeared in the last hour or so.
Clicking post options zooms to the top of the page (something Jack fixed a while back IIRC).
Clicking Username/Avatar for fly-out goes straight to Profile
Moving between RT/HTML/Preview is giving the Leave page warning.
I doubt that's all of them Shocked
Edit: Forgot going slow appeared.
141 REPLIES 141
Oldjim
Resting Legend
Fixes: 63
Re: Priority - Forum bugs have appeared
Using Firefox
Username - takes me to the flyout
Moving between RT/HTML/Preview doesn't give the leaving page warning
One thing I have noticed is that when selecting edit the edit screen starts of showing the html code then milliseconds later goes to Rich Text
Clicking on Post Options doesn't go to the top of the page
Anotherone
Champion
Fixes: 21
Still getting those, and on a different device and have cleared caches and rebooted.
The menu drop-down bugs are intermittent now, as is the Page Leave in some instances.
mtrinder
@Anotherone wrote:
@mtrinder@Chris@bobpullen
I published the text colour changes 20 minutes ago. Do you think that these incidents coincided, or is it possible the bugs were already present? (It's important for us to know if we're breaking anything with a supposedly minor update).
Cheers,
Anotherone
Champion
Fixes: 21
The fly-out menu was definitely present much before that, the others I wouldn't have noticed  if I wasn't using the options, but I think I had the drop-down menu one and probably didn't think too much of it at the time. HTH.
mtrinder
Ok I'll make sure these get captured and looked at. Sounds like it wasn't caused by the last update, which is a relief!
wisty
Fixes: 8
This looks to me like another Javascript issue.
Using Firefox/Waterfox with Java enabled it works fine. Using MS Edge which disables Java I get exactly the same problem as Anotherone.
Anotherone
Champion
Fixes: 21
Well I have Javascript enabled, and I'm not the only one that saw this.
mtrinder
I'm getting the problem intermittently in firefox but not at all in chrome. Peculiar.
Anotherone
Champion
Fixes: 21
They are intermittent we me too, but more rather than less.
mtrinder
Yeah same here (on FF anyway).
We're releasing updates weekly at the moment, so we'll try and ensure that some of these get sorted in next weeks update.
Thanks for raising the issues, keep 'em coming Thumbs_Up
Anotherone
Champion
Fixes: 21
Well none of these were here earlier this morning, and the fly-out menu one is a major nuisance, the others will be especially on a mobile device, so if you can resolve these much more quickly I think we'd all appreciate it.
Anotherone
Champion
Fixes: 21
One more to add to the list @mtrinder, just went to mark a post I'd just read as 'Mark as New' and got Authentication error - the one that suggests Javascript isn't enabled (I've since achieved it with out error and with any other changes)
Anotherone
Champion
Fixes: 21
Any update @mtrinder? All problems continue the same.
mtrinder
Hi @Anotherone,
It's unlikely we'll be making any more updates to community today, these bugs will take a little time to root out - but we'll do our best to get an update out early next week.
Cheers,
