File Upload - Drag 'n' Drop only works once.
- Feedback
- Community Site Feedback
- Re: File Upload - Drag 'n' Drop only works once.
14-08-2016 1:46 PM
I've just uploaded a couple of images to another forum here, but while doing it I could only load one image via D'n'D as it didn't work after the first image. I wanted to load them one at a time so I could title them and put them in the correct order. I know I can use the Browse option as I ended up doing but D'n'D is so much easier.
I don't suppose that this is the intended mode of operation, so am I doing something wrong or is there an issue with this component?
14-08-2016 1:54 PM - edited 14-08-2016 3:21 PM
you need to wait until the bar under the first image goes
14-08-2016 2:50 PM - edited 14-08-2016 3:22 PM
I assume by that @Oldjim you mean the uploader bar, that when finished allows you to enter the image title? If that's the case then I always do. But the D'n'D text that originally appears in the middle of page doesn't re-appear and dragging to the area to the right of the uploaded image does nothing; for me at least.
14-08-2016 3:02 PM
14-08-2016 3:20 PM - edited 14-08-2016 3:22 PM
so did I - will need to check
OK this is odd
The original image came from a post on the testing site and I did a copy and paste but instead of posting the image it posted the link
Now sorted
14-08-2016 3:24 PM
14-08-2016 3:30 PM
Prompt gone and I can see the image ![]()
15-08-2016 8:49 AM
You guys got that prompt because @Oldjim added a photo from the staging site and tried to show it directly from there. Jim has since reuploaded the file to this site instead so the password prompt should no longer be showing.
15-08-2016 9:55 AM
as I said in post 5 ![]()
15-08-2016 10:51 AM
Thanks @Oldjim. I thought I would acknowledge this as I received a PM about it.
18-08-2016 11:05 AM
I have identified a bug and issued a fix on the staging site.
Basically what I had done is remove the 'image' icon that is displayed on the drag-n-drop box but didn't realise this would have an affect on the drag and drop function if you were to upload single files using this method. I have now reinstated the image icon as that is what was keeping the container open when the file reached the bounds of the container.
This fix will be rolled out with the next update (which should be a lot sooner than the last update interval).
18-08-2016 2:15 PM
Thanks @jaread83
18-08-2016 2:16 PM
- Feedback
