Change Password?
Alex
Fixes: 13
Change Password?
Good old Lithium, aside from the useful spell checker being removed, the really 'helpful' Feedback tab that never seemed to disappear .. now I have the fun and games of not being able to change my password.
My fault as the one I think I used doesn't work and I can't find where I stored it.
I only managed to log in using details already stored on my phone with my finger print.
If Lithium, logic and PlusNet QA testing existed then the option would have been available after you logged in under account details when I click my name.
3 REPLIES 3
Fixes: 1,664
Re: Change Password?
If you go to your avatar at the top right, then click on My Settings, in the drop down under Personal Profile, select Password, and you can change it from there.
Alex
Fixes: 13
Thanks @Gandalf, sorry having a stressful day yesterday anyway (outside of PlusNet, so I was more grumpy than I usually am!) but I think that has done that now.
Fixes: 1,664
No worries, everyone has off days and I hope all's okay now.
