Are Lithium ever going to fix the unread posts bug?
Alex
Fixes: 13
Re: Are Lithium ever going to fix the unread posts bug?
Fair enough @Townman
If that is the way it is, then fine. It is just I find it quite useful.
I don't know PlusNets back end systems of course, so I can't tell what is causing it.
I chose a bad title for this thread, and it is the New flag I was referring to. I hadn't even noticed the bug you mentioned which as you say is now fixed.
Fixes: 240
Alex,
Fixed some of the time. I think Strat said above that he sometimes sees the issue still.
To be honest I had not read the thread as the notification issue ... maybe because I did not read it diligently ... and was all too well aware of the intermittent sticky unread posts issue.
Fixes: 1,653
The notifications menu has always worked like that since we moved to this forum. It’s like Facebook’s notification menu where you’d just need to open the menu up to view the new/read and in doing so it marks all the notifications as read. As it seems to be working by design, it’s not a problem I can raise but I agree it would be a good improvement or enhancement.
