Routing issues (74057) - NEW
Oldjim
Resting Legend
Fixes: 63
Re: Routing issues (74057) - NEW
Absolutely and this library article also covers it for the earlier routers http://community.plus.net/library/dns/how-to-change-the-default-dns-servers-in-a-thomson-speedtouch-...
this is the section from the Netgear basic settings screen
Anotherone
Champion
Fixes: 21
I shall have to go away and play with my 582n then. Thanks for enlightening me, but I thought it best to warn that some will require a reboot.
NedLudd
I just left the 582n alone and put new DNS server addresses in Network Properties. No need to re-boot anything. It just worked!
Geoff,
York.
pwatson
Is there still an issue?
My TBB graph (below) shows the effect of the routing problem between 1PM and 2PM (until I rebooted the router which presumably changed the gateway) but the performance from 8PM is worrying!
Kelly
Fixes: 9
Ouch.  Give the router a reboot?
Kelly Dorset
Ex-Plusnet Jobsbody
pwatson
Just trying that...
I didn't make a note of what gateway I was on before rebooting though Sad
I'm now on pcl-ag02
Pings to www.bbc.co.uk now back to a consistent 11ms - Again, didn't try this before rebooting Sad
pwatson
Seemingly not just me - See the lower plot from mikeb on ADSL (I'm on FTTC)
bobpullen
Fixes: 331
Very odd. Just checked over here and I'm not seeing any other examples?  Huh
tijara33
Fixes: 6
My graph is just becoming noisy!!
