Peak time latency spikes
chrispurvey
Re: Peak time latency spikes
Anybody connected to pcl-ag07 or pcl-ag08 and seeing any problems that started around 7pm tonight, can you stay on that gateway and see if everything is OK?
chrispurvey
Quote from: jamesanstee
Think i spoke too soon speed gone down the pan again
You are currently connected to gateway pcl-ag08
Dave has replied to you on IRC, any improvement for you?
DaveyH
Champion
Fixes: 12
Haven't been suffering with peak time latency too badly until tonight.
Noticed  i was getting lots of buffering on iplayer an navi-x when i usually get none
TBB BQM
http://www.thinkbroadband.com/ping/share/f9d4cdca30a9964632964cca5e97e01f.html
'You are currently connected to gateway pcl-ag08.'
chrispurvey
Hi DaveyH,
Could you stay connected to that gateway while we look at your line, would it be possible for you to pop onto IRC so we could discuss in real-time and not miss anything? Me and Dave are on there.
DaveyH
Champion
Fixes: 12
Quote from: chrispurvey
Still on pcl-ag08 and seems to be returning to normal now
jamesanstee
BT Wholesale speed test result .
Gus
Was anything being tried in background from 9.30pm till 9.50pm?  I am and was in Lotro, from 9.30pm onwards to 9.50pm I couldn't move in game or logout.  Ping trace/wireshark/speedtests all normal for this time of night.
edit forgot on  ptw-ag02
FTTP 500 regrade from Tues 28th November
chrispurvey
Hi Gus, we're just looking into that. How are things at the moment?
Gus
@chrispurvey fine at the moment, I was checking as there was a game patch today which might be the problem or the cherry on top of it, as I am now seeing reports of other Lotro servers having problems.
Side note, tried to type this earlier but the reply button for this thread timed out, but this thread is png heavy so expect it to a point.
rookey
Mine didn't look good this morning
AndyH
rookey
I did though about that after I posted oops
Did something happen around 09:30 this morning ?
I started browsing about midday, and every website I visited was like treacle.  My first thought was that I must have exceeded my allowance (which is very likely to happen today), but I checked VMBU and I still have 200MB to go.  Next I did a speedtest which showed >95% of profile BUT also showed my ping had gone from 19ms to 29ms.  Had a look at the TBB graph and sure enough there had been a step in latency -
Checking my router log, there had not been a resync, or even a session drop.
Router synced at full speed, no errors, and normal line stats.
Using the gateway checker I was still on the same gateway that I was on yesterday - but with a 10ms extra latency.
I also checked to see whether the connection had become interleaved, but no it was still on fastpath.
I then tried five different gateway hops, and they are all showing the increased latency (+/- 1ms)
Anyone got any idea what happened at 09:30 ?  Undecided
Anotherone
Champion
Fixes: 21
Whether this could have made any difference, I don't know, but it wasn't scheduled for 0930, so perhaps Kelly, Bob or Dave may know.
cihan
Yep, terrible speeds for me too in Bromley, Kent (or SE London)
(I'm on Mac and don't have (or want) Java so the ping test skipped a test)
Websites are slow, but streaming Youtube is impossible. Haven't tried PS3 online but no point considering the test results above. Problem started this morning, though to be honest I've found the Plusnet connection to be erratic on random occasions the last six months, connection dropping or slow speeds. It's not regular enough for me to complain about, but today I decided to roam the forums and found this thread, so here I am chipping in.
I'm using the standard Netgear router that came with the package, wireless, though it's right beside my Mac as I type.
