Peak time latency spikes
apjashley1
Re: Peak time latency spikes
Still having issues! (Birmingham Central)
Anotherone
Champion
Fixes: 21
Just to advise no nasty latency during the evening seen on TBB monitor for one 21CN user on pcl-ag02. HTH.
Bright
Likewise, no problems at all last night on 21CN FTTC. Gateway: pcl-ag05
MrRichThomas
@Anotherone: Sorry I missed your reply last night, I was busy sucking at Halo 4  :-[. I'll try the bt speedtest tonight if I get the same problems.
My speeds are back to normal now, and my Monitor shows no signs of latency from last night, despite my dreadfully slow speeds and higher pings. Also, I was not on pcl-ag07 or 08 apart from for a minute or so. Still on ptn-ag03 since my hop last night.
Anotherone
Champion
Fixes: 21
Well that looks a lot better, there is obviously nothing wrong at this time with your sync speed to the Cab either. Running the BT Diagnostic test as mention earlier, you can check your IP Profile for the line which should remain constant if you aren't having drops.
MrRichThomas
Bt Speedtest results below, I'm fairly certain my profile has been 77.4 since my service was activated on 17th Jan. I'l do another one tonight if/when the slowdown starts.
Download speed achieved during the test was - 73.12 Mbps
For your connection, the acceptable range of speeds is 16 Mbps-77.44 Mbps .
Additional Information:
IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 15.13Mbps
Anotherone
Champion
Fixes: 21
Blimey, the Cabinet must be in your front garden  Shocked
MrRichThomas
Not quite! It's at the end of the road though, probably 100 yards away, if that.
ricmelia
ptw-ag02
not so great tonight
Download speed achieved during the test was - 38.99 Mbps
For your connection, the acceptable range of speedsis 16 Mbps-77.44 Mbps .
Additional Information:  IP Profile for your line is - 77.44 Mbps
Upload speed achieved during the test was - 15.54Mbps
Additional Information:  Upstream Rate IP profile on your line is - 20 Mbps
MrRichThomas
Mine's awful again. Bearing in mind this morning I was getting 73Mb down....
ricmelia
and now it's fine...
I'm streaming audio now, wasn't before..!
walterhornby
Whilst my download speeds have been ok today, seems the packet loss has been bad according to TBB graph.  This is on gateway pcl-ag04.
ricmelia
are you sure your router is still accepting ping requests? did anything happen at 12:15ish?
Fixes: 1,495
suspect they're not on static ip and the IP address changed..
walterhornby
Quote from: ricmelia
Far as I know it's still accepting ping request, not sure how to check that.  And far as I knowe nothing happened at around that time.
