Peak time latency spikes
Exdee
Re: Peak time latency spikes
C:\Users\X>ping bbc.co.uk
Pinging bbc.co.uk [212.58.241.131] with 32 bytes of data:
Reply from 212.58.241.131: bytes=32 time=346ms TTL=243
Reply from 212.58.241.131: bytes=32 time=227ms TTL=243
Reply from 212.58.241.131: bytes=32 time=314ms TTL=243
Reply from 212.58.241.131: bytes=32 time=287ms TTL=243
Ping statistics for 212.58.241.131:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 227ms, Maximum = 346ms, Average = 293ms
C:\Users\X>tracert bbc.co.uk
Tracing route to bbc.co.uk [212.58.241.131]
over a maximum of 30 hops:
  1    *      23 ms  139 ms  dsldevice.lan [192.168.1.254]
  2  220 ms    53 ms    19 ms  lo0-central10.pcl-ag08.plus.net [195.166.128.189]
  3  186 ms    22 ms    18 ms  link1-central10.pcl-gw01.plus.net [84.93.249.224]
  4  363 ms  235 ms  292 ms  xe-2-2-0.pcl-cr01.plus.net [212.159.1.12]
  5  322 ms  282 ms  430 ms  ae2.pcl-cr02.plus.net [195.166.129.7]
  6  231 ms  443 ms  225 ms  ae2.pcl-cr01.plus.net [195.166.129.6]
  7  307 ms  434 ms  428 ms  ae1.ptw-cr01.plus.net [195.166.129.0]
  8  285 ms  419 ms  271 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
  9    *        *        *    Request timed out.
10  264 ms  300 ms  499 ms  ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
11  414 ms  267 ms  192 ms  132.185.255.60
12  190 ms  198 ms  322 ms  virtual-vip.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
Sad
Cascy
Anotherone - thanks - did that and now on  ptn-ag01 and back to normal speed. Much appreciated.
shalom2010
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
C:\Windows\system32>ping bbc.co.uk
Reply from 212.58.241.131: bytes=32 time=18ms TTL=246
Reply from 212.58.241.131: bytes=32 time=17ms TTL=246
   Minimum = 17ms, Maximum = 18ms, Average = 17ms
C:\Windows\system32>tracert bbc.co.uk
 1    46 ms    98 ms    98 ms  dsldevice.lan [192.168.1.254]
 2    20 ms    18 ms    19 ms  lo0-central10.ptw-ag03.plus.net [195.166.128.197
 3    19 ms    18 ms    17 ms  link10-central10.ptw-gw02.plus.net [84.93.248.82
 4    17 ms    17 ms    18 ms  xe-7-2-0.ptw-cr02.plus.net [212.159.1.22]
 5    17 ms    17 ms    17 ms  ae2.ptw-cr01.plus.net [195.166.129.4]
 6    17 ms    16 ms    17 ms  kingston-gw.thdo.bbc.co.uk [212.58.239.6]
 7     *        *        *     Request timed out.
 8    64 ms    18 ms    18 ms  ae1.er01.rbsov.bbc.co.uk [132.185.254.46]
 9    22 ms    17 ms    22 ms  132.185.255.60
10    17 ms    18 ms    17 ms  virtual-vip.thdo.bbc.co.uk [212.58.241.131]
Trace complete.
Only Usenet affected here
Necrotix
Hi guys,
I am new to Plusnet. Just got mine activated today.
Wow, isn't this a throwback to Entanet-esque shenanigans? I didn't think i'd see the day.
Anyway, I am on gateway pcl-ag06. Ping times and speeds are normal. I WAS on pcl-ag07 and it was absolutely dire (200ms pings, 3mb speeds)
I reckon what has happened is Plusnet have probably got an influx of new customers and it's hammering their systems.
MrRichThomas
Sorry, didn't realise a reboot was different to a disconnect, I used the reboot the other night too..  Embarrassed
I just hopped briefly onto pcl-ag07 and it was atrocious:
So hopped again onto ptn-ag03 and it's slightly better, although a long way from my 70mb down, 9ms ping.
Exdee
Shocked
Even ADSL was 10x faster lol
Anotherone
Champion
Fixes: 21
@MrRichThomas
As you are on Fibre it's not so critical with the router, but it could be disastrous for an ADSL user depending on their connection.
But those speeds are really bad. Try another Gateway hop. Also run http://speedtest.btwholesale.com/ ignore the red pre-amble except make sure nothing else is using the Internet, after the first test Click Further Diagnostics, enter your phone number and run the test.Copy and paste the result.
jamesanstee
gateway pcl-ag04seems to be stable for the moment but with the traffic elevation plusnet made to my line does not seem to have made any difference during peak time .
BingoBev
I jumped from pcl-ag01 where I was getting 1-2mbps to pcl-ag05 and now getting 67-70mbps.  Slightly slower than normal 80mbps but much better.
Kelly
Fixes: 9
I just got in and checked the graphs and spotted this:
http://www.thinkbroadband.com/ping/share/660bb73c13549817d7f965387a399f8e.html
Looks like we've had something push that same device again into failure.  Just called someone to sort it.  This would have affected anyone on pcl-ag08, pcl-ag07.
Kelly Dorset
Ex-Plusnet Jobsbody
jamesanstee
Pcl-ag08 that would explain the high ping of 183ms then.
MsDizzie
Quote from: Kelly
It wasn't me guv honest  Shocked (at least for pcl-ag08  Grin ) but I do wonder what happened at 4:30 this afternoon to kick this all off?
kareha
Been gaming all night then logged of to watch some YOUTUBE.  Videos start buffering so had to knock it down to 480p Sad
Gateway is ptn-ag03.
Download speeds are fine, but I usually have a ping of 30 and 0-1 jitter.
20CN,  'pcl-ag07'
Kelly
Fixes: 9
