Peak time latency spikes
- News & Announcements
- Community Announcements
- Peak time latency spikes
Re: Peak time latency spikes
02-03-2013 10:06 PM
Quote from: dvorak suspect they're not on static ip and the IP address changed..
If you mean me, then yes, not on a static ip.
02-03-2013 11:45 PM
You need to go to TBB and delete your old monitor and create a new one.You will need to do that every time your IP address changes ie. everytime you Gateway Hop or lose connection.
03-03-2013 7:42 AM
jim:quote
03-03-2013 4:22 PM
03-03-2013 4:44 PM
03-03-2013 6:51 PM
gateway ptn-ag01
Then on to ptw-ag02
Then on to gateway pcl-ag07 , speed is getting better , ping is getting higher
Then on to gateway pcl-ag08 lower speed and lower ping
Then on to gateway pcl-ag02
Then on to gateway ptn-ag03
Then back to gateway pcl-ag08
After 15 mins from been off the above gateway , it seems to be working ok for the moment .
Six gateway hops to six different gateways and all not performing as they should.
PN i hope this is sorted soon, this is becoming more and more frustrating.
Regards
Mike
03-03-2013 6:53 PM
03-03-2013 7:49 PM
03-03-2013 7:57 PM
03-03-2013 8:06 PM
03-03-2013 8:07 PM
(Used to 50Mb/s+)
03-03-2013 8:30 PM
03-03-2013 9:56 PM
03-03-2013 11:04 PM
Now ended up on pcl-ag01 which seems OK at 11pm but by this time each night the problem is normally over, lets see what tomorrow brings.
Update
6.25am on 4.3.13 speed tests all 51 to 52Mb everything seems to be running at max, so my problem seems to happen between 4pm and 11pm and speed slows down for a 2 hours slot drops as low as 2Mb still on gateway pcl-ag01. Lets seem what tonight brings.
03-03-2013 11:37 PM
Quote from: jamesanstee Im not experiencing any slow downs both yesterday and today has been perfect.
Could you say which gateway you're on please?
http://usertools.plus.net/@gateway/
