Gateway Checker Update
- News & Announcements
- Community Announcements
- Re: Gateway Checker Update
13-10-2015 9:49 PM
acc2-10GigE-0-4-0-10.l-far.21cn-ipp.bt.net (109.159.249.134) 3.583 ms
195.99.126.99 (195.99.126.99) 2.606 ms
ae2.pcl-cr01.plus.net (195.166.129.6) 49.815 ms
ae1.ptw-cr01.plus.net (195.166.129.0) 3.444 ms
link3-central10.pcl-gw01.plus.net (84.93.249.196) 3.438 ms
13-10-2015 10:17 PM
David
13-10-2015 10:49 PM
16-10-2015 9:10 PM
Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
Posting the following information as a reply to the Gateway Checker Update topic in the Community Announcements forum will help us to diagnose the problem.
link11-central10.pcl-gw01.plus.net (84.93.249.212) 3.794 ms
Alan
16-10-2015 10:47 PM
David
18-10-2015 10:44 AM
xe-1-2-1.mpr1.lhr18.uk.zip.zayo.com (64.125.29.217) 4.525 ms
xe-5-0-0.mpr1.lhr1.uk.zip.zayo.com (64.125.29.114) 4.508 ms
213.137.183.97 (213.137.183.97) 4.857 ms
core4-te0-8-0-1.faraday.ukcore.bt.net (62.6.201.196) 5.154 ms
acc2-10GigE-0-1-0-1.l-far.21cn-ipp.bt.net (109.159.249.146) 4.478 ms
195.99.126.99 (195.99.126.99) 4.548 ms
just gone onto thinkbroadband to do speed test and it says am on BT when it normally says on plusnet
18-10-2015 10:58 AM
Quote Sorry, the tool failed to identify your gateway; this does not mean that anything is wrong with your connection.
213.248.82.250 (213.248.82.250) 2.214 ms
166-49-211-239.eu.bt.net (166.49.211.239) 2.039 ms
core2-te0-15-0-13.ilford.ukcore.bt.net (109.159.255.98) 7.262 ms
194.72.31.139 (194.72.31.139) 4.571 ms
195.99.126.139 (195.99.126.139) 3.907 ms
ae2.ptw-cr02.plus.net (195.166.129.5) 3.876 ms
ae1.pcl-cr02.plus.net (195.166.129.3) 3.818 ms
This may be useful:
C:\Users\John>tracert ntp.plus.net
Tracing route to ntp.plus.net [212.159.6.9]
over a maximum of 30 hops:
1 <1 ms 1 ms 1 ms tg582 [192.168.1.254]
2 10 ms 9 ms 9 ms lo0.10.Central10.pcl-bng04.plus.net [195.166.130.177]
3 10 ms 10 ms 9 ms irb.10.PCL-CR01.plus.net [84.93.249.81]
4 10 ms 10 ms 10 ms po2.pcl-gw01.plus.net [195.166.129.41]
5 10 ms 9 ms 9 ms cdns01.plus.net [212.159.6.9]
Trace complete.
18-10-2015 11:00 AM
18-10-2015 12:51 PM
xe-1-2-1.mpr1.lhr18.uk.zip.zayo.com (64.125.29.217) 25.120 ms
xe-5-0-0.mpr1.lhr1.uk.zip.zayo.com (64.125.29.114) 25.085 ms
213.137.183.103 (213.137.183.103) 25.035 ms
core3-te0-8-0-1.faraday.ukcore.bt.net (62.6.201.192) 25.072 ms
peer1-et-1-1-0.telehouse.ukcore.bt.net (213.121.193.161) 25.054 ms
195.99.126.139 (195.99.126.139) 25.050 ms
Alan
18-10-2015 1:44 PM
Quote from: spoon What is going on?
It looks like Rackspace have introduced additional routing within their cloud which has added extra hops to the path to user gateways. Jelv's router is now hop 15, mine is hop 17. The checker currently stops at 13. It's possible the additional hops are temporary, whilst maintenance is carried out, but in the meantime I'll increase the checker's maximum hop allowance which should fix the current problem.
(goatty2 apparently having a BT IP is a different issue - more on that later.)
David
18-10-2015 1:47 PM
xe-1-2-1.mpr1.lhr18.uk.zip.zayo.com (64.125.29.217) 4.803 ms
xe-5-0-0.mpr1.lhr1.uk.zip.zayo.com (64.125.29.114) 4.959 ms
213.137.183.101 (213.137.183.101) 7.380 ms
core3-te0-8-0-1.faraday.ukcore.bt.net (62.6.201.192) 5.076 ms
peer6-hu0-18-0-1.telehouse.ukcore.bt.net (213.121.193.177) 5.509 ms
195.99.126.183 (195.99.126.183) 4.747 ms
18-10-2015 2:13 PM
18-10-2015 2:15 PM
Quote from: spraxyt ... in the meantime I'll increase the checker's maximum hop allowance which should fix the current problem.
I've increased the maximum hops to 20 now - could users getting gateway identification failures earlier please check again.
David
18-10-2015 2:59 PM
18-10-2015 3:00 PM
(You do realise you've just broken Plusnet's standard operating procedures by fixing the issue straight away. Left to Plusnet a simple change like that would have taken months!)
