Moving from virgin to Plusnet
John_
I have been with Virgin business for years phone only. But now it's time to get some internet and they can supply it.
So how do I go about keeping my current number when I change to plusnet?
your online postcode checker says I'd need a new phone number which isn't going to happen!
19 REPLIES 19
John_
Re: Moving from virgin to Plusnet
By the way I've asked this twice by email and not got a reply... Not filling me with confidence
Mustrum
Fixes: 77
You asked the question three years ago, the answer won't have changed. https://community.plus.net/t5/Home-Phone/Moving-from-virgin/m-p/1413811
There is no email adress to ask questions, so not sure where you sent them to?
John_
That was for home not work!
There is a business email, just a shame noone answers it
Fixes: 1,601
Hi @John_ I'm sorry to see you've not had a reply back yet from the email you've sent. How long ago did you send this so I can chase this up?
With regards to your query it doesn't really make a difference if you're a home or business user when it comes to importing a number across. As long as your number is active and you've told us what the number is when you check for the availability of broadband at your address it should be fine.
When you've submitted your order we'll then tell you if we can't keep your number and you'll be able to cancel your order if you want. Feel free to post back if you do place an order and we'll be happy to check up on this.
John_
I've made my order now, thanks for your help.
Fixes: 1,601
No problem @John_
We'll check this tomorrow for you Smiley
John_
I got a automated email over the weekend. Saying my order has been cancelled. And someone would be in touch to explain problem.
As of today no one has
Fixes: 1,601
Hi @John_
I'm sorry for the confusion regarding the notification you've received about your order being cancelled. When you first signed up our system had problems passing the order to our suppliers and it looks like that was a delayed notification.
I've checked your order through and I can see everything's still on track for your engineer appointment to take place between 8am and 1pm on the 29/01/20. Apologies again for the confusion we've caused.
John_
Thankyou, that's what I wanted to hear.
Fixes: 1,601
No problem John, fingers crossed all goes smoothly on the day
John_
Today the openreach engineer came and put the new line in.
Now I can't dial out at all and only get incoming on the temporary number rather than my original number.
Engineer says tests come through good.
I hope this fixes itself by the time I open tomorrow morning!
Fixes: 1,601
Thanks for getting back to us @John_
The order isn't completed yet so it's likely that there's something stopping your service from working on a backend system. It should complete before midnight tonight. Let us know if you're still having issues tomorrow.
Apologies for the inconvenience.
John_
Thank you, I have my fingers crossed you are right.
Fixes: 1,601
No problem John, I'll happily investigate further if you still can't use your service tomorrow
