Can't change from dynamic to static IP
pbouch
I have a business account and want to change to a static IP address. However, after I click the button to switch to static, it takes me to a blank page and does nothing. I've tried restarting my router and my PC but it makes no difference. How can I fix this?
7 REPLIES 7
adam945
Fixes: 113
Re: Can't change from dynamic to static IP
Hello @pbouch
Thanks for getting in touch, I should be able to sort this out for you. Are you after a single static IP, or a block of 4 / 8 ?
 Adam
 Plusnet Help Team - Leeds
pbouch
A single static IP would be great, thanks!
adam945
Fixes: 113
That;s all been sorted out for you @pbouch
I'll send you a PM with the IP address in a sec Smiley
 Adam
kiaorak
you found a button? More than I have managed to Sad
Alex
Fixes: 13
@kiaorak
Are you suffering from the same problem?
If so, then let us know more information. Maybe your post should be split off into a new thread.
Fixes: 240
@Alex There is a separate thread ... as well!
LaurenB
Fixes: 131
Hiya @kiaorak, I have responded further on the thread you have created Smiley
 Lauren Barry
