Can't change from dynamic to static IP
- Business
- Re: Can't change from dynamic to static IP
31-01-2022 3:53 PM
I have a business account and want to change to a static IP address. However, after I click the button to switch to static, it takes me to a blank page and does nothing. I've tried restarting my router and my PC but it makes no difference. How can I fix this?
31-01-2022 4:27 PM
Hello @pbouch
Thanks for getting in touch, I should be able to sort this out for you. Are you after a single static IP, or a block of 4 / 8 ?
31-01-2022 5:02 PM
A single static IP would be great, thanks!
31-01-2022 5:12 PM
That;s all been sorted out for you @pbouch
I'll send you a PM with the IP address in a sec ![]()
11-05-2022 11:17 PM
you found a button? More than I have managed to ![]()
12-05-2022 10:11 AM
Are you suffering from the same problem?
If so, then let us know more information. Maybe your post should be split off into a new thread.
12-05-2022 10:29 AM
@Alex There is a separate thread ... as well!
12-05-2022 11:46 AM
Hiya @kiaorak, I have responded further on the thread you have created
- Business
