samsung smart TV
- Re: samsung smart TV
samsung smart TV
03-03-2013 7:26 PM
dunno if its right to post here , cheers Jim for putting it in right place
OK i have just bought a samsung smart TV . i am fibre 80/20 with the Netgear WNR 1000 v3 , the TV finds the router and works on the WIFI but is slow so i just got a CAT5 extension lead and connected the TV direct to the Router , but it says connected but when select web browser it just stay on connecting for ever .
Router lists it as connected .
any ideas ?
any ideas ?
Message 1 of 9
(1,956 Views)
8 REPLIES 8
03-03-2013 7:44 PM
So, what are the differences in settings between wireless and wired?
DCHP or fixed addresses?
Are the DNS settings the same?
What is the TV "failing" to connect to - web site/media server/iplayer?
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
Message 2 of 9
(783 Views)
03-03-2013 10:08 PM
settings are on auto ,
it just carries on sayin "conecting " and stays there for ages
Message 3 of 9
(783 Views)
03-03-2013 10:31 PM
A somewhat random question, as I don't know the TV. Does the TV turn off wireless automatically if a cable is connected, do you have to select from the two or do you enable/disable independently? Put another way, make sure only one interface is active at any time as otherwise anything can happen
Message 4 of 9
(783 Views)
04-03-2013 7:14 AM
yup as soon as i plug cable in it turned off the wifi
Message 5 of 9
(783 Views)
04-03-2013 7:18 AM
The Samsung Smart TV service is down at the moment, which is why you can't connect. I (and many others, just search Google) cannot connect either.
Message 6 of 9
(783 Views)
04-03-2013 7:26 AM
This happened to me yesterday with same tv. Had been connecting since start of year ok, but then upgrade from Essential to Unlimited Fibre yesterday and would not connect. Just hung there for ages saying "connecting". Had to reset many times but eventually did pull through the connection. But is not working this morning again.
Not sure if there was something going on with DNS settings yesterday, or whether upgrading changed something. Most odd. The only way I could connect was using the wps button on the Thomson router. That connected me, but as soon as tried again, it failed to access content.
Message 7 of 9
(783 Views)
04-03-2013 7:10 PM
Have you tried doing a full reset by going into the installation menu? Did that with mine, putting everythign abck to factory settings and that worked. Smart hub now reconencting with apps.
Message 8 of 9
(783 Views)
04-03-2013 9:30 PM
NewStu yup thats what i did and its fine now
Message 9 of 9
(783 Views)
