my drop cable splits into two wires - is this normal/ok?
- Re: my drop cable splits into two wires - is this ...
- « Previous
- 1
- 2
- Next »
Re: my drop cable splits into two wires - is this normal/ok?
09-12-2016 3:48 PM
And do Plusnet quote people the B range of speeds in case they have unfiltered extension sockets? I don't think you do. Your "rare exceptions" are anyone who has more than one phone socket and lacks a centralised filter.
10-12-2016 3:31 PM
@MattyC wrote:
In some instances, we recommend checking with local electricians to see if they could arrange things for you. A new NTE5 master socket would probably improve the experience.
I certainly would not recommend this approach @MattyC. Electricians generally have limited experience of Telecomms wiring apart from connecting wires between points. Seen a number of jobs completed with straight multi-core not proper twisted pair - OK it normally works for the phone, but ADSL / FTTC? Much better to look in the local small ads for an ex(?) BT man who will do a much more reliable job.
15-12-2016 5:10 PM
Just a final thank you to those who offered their comments. It's been helpful and my options are clearer now.
nox
- « Previous
- 1
- 2
- Next »
