Upload speed 0.37Mbps Download speed 5.46Mbps
bigredbus
BB speed especially Upload speed is deadly slow.
Is this normal speed or is there any issues?
Fixes: 161
Re: Upload speed 0.37Mbps Download speed 5.46Mbps
I've placed a order to improve your upload speeds.
This is due to complete tomorrow and should give you a boost.
 Matthew Wheeler
bigredbus
Hi, Thank you for your message but it seems still nothing changed the situation.
Would you please confirm it?
Thank you.
Fixes: 10
Try a disconnect/connect if you haven't already done that.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
bigredbus
Hi, thanks for your message.
I turned on and off  but nothing changed.
Plusnet Staff
Plusnet Staff
Fixes: 116
Upstream DSL Link Information Downstream DSL Link Information
Loop Loss: 25.8 44.5
SNR Margin: 23.0 6.1
Errored Seconds: 0 3
HEC Errors: 0
Cell Count: 28355 34715
Speed: 443 6319
From the results above, the downstream speed is above your estimated speed but upstream remains capped. I'll place a modify order now to uncap it within the next 24 hours.
From when I joined the Plusnet Help Team in May 2017 my main Community account is @Gandalf.
 Plusnet Staff
bigredbus
Hi, Nothing still improved yet.
Please confirm?
Thanks,
Plusnet Staff
Plusnet Staff
Fixes: 116
Hmm, sorry to hear you haven't noticed an improvement.
I've set myself a reminder to check on your account once I'm back in the office tomorrow.
Thanks for your patience.
Upstream Link Info
Loop Loss SNR Margin Errored Seconds Hec Errors Cell Count Speed
26 23 0 0 3916806 443
Downstream Link Info
44 6.1 7 N/A 17128964 6419
Yeah, the upload sync hasn't changed despite the orders my colleague and I have placed. I've manually modified the upstream SNR margin which should increase the sync.
 Plusnet Staff
bigredbus
Thank you for your help.
I tried to check upload speed this afternoon couple of times but seems to be nothing changed yet.
Please check?
Thank you.
Plusnet Staff
Plusnet Staff
Fixes: 116
Hmm, I've reset the line as the next step.
Can you reboot your router after approx. 4 hours and let me know how it goes?
Thanks.
 Plusnet Staff
ian007jen
Is this on an old adsl (g.dmt) only exchange....max upload sync would be 443 kbps
Fixes: 10
If it was 20CN the sync would be 448 and sync speeds on 20CN are even numbers. 443 is a classic capped 21CN ADSL2 symptom.
bigredbus
Thanks but still the same.
Fixes: 162
I'm just looking in to this further, the orders all completed to uncap the line but when testing it's still showing the profile as WBC 160K - 24M No delay (INP 0) 6dB Downstream, 448 No delay (INP 0) 6dB Upstream (ADSL2+)
 Chris Parr
 Plusnet Staff
Fixes: 162
Upstream Link Info
26 6 0 0 392518 1007
44 6.1 4 N/A 1671885 6259
Sorry for the delay sorting this out, I've just been on a lengthy conversation with BTWholesale about this but it looks good now!
 Chris Parr
 Plusnet Staff
