low speeds and disconnections
- low speeds and disconnections
03-02-2014 4:20 PM
My broadband connection is dropping and disconnecting and when i tried to run a bt diagnostics test, my connection disconnected again?
Message 1 of 4
(558 Views)
3 REPLIES 3
Re: low speeds and disconnections
03-02-2014 4:25 PM
I've got a graph of your connection here:
<img src="http://community.plus.net/visualradius/generated/image139144464436.png"/>
Your connection looks pretty solid to me. Not sure why it's dropping you out on the BT Diagnostics page. Does it allow you to complete the initial Speed Test?
Message 2 of 4
(361 Views)
03-02-2014 4:26 PM
Jason, are you connected over wireless? If so try turning your wirless off on your PC and plug an ethernet cable in, do you still get disconnects then?
Message 3 of 4
(361 Views)
03-02-2014 4:40 PM
i tried wired connection when i ran the test it came up just over 3mbps download and 0.79mbps upload but when i tried to further diagnostics test it disconnected
Message 4 of 4
(361 Views)
