internet is appauling now
- internet is appauling now
Re: internet is appauling now
20-08-2014 4:07 PM
Can you click on http://192.168.1.254 you'll first get the login screen and then it will give the page required. Then copy and paste that here similar to what you did for the stats before, BUT delete the MAC address at 1.3 and the IP address at 3.3 from the pasted bit.
Are you using wireless to connect your Xbox and Computer or Ethernet cable?
Lastly, just to check, has your 582n got a USB port on it at all?
20-08-2014 6:42 PM
And can u give me significant instrusctions of what u want as my head is frazzled.,
20-08-2014 6:59 PM
Just click on this link http://192.168.1.254 ; you'll get the modem/router log in screen, admin should be the user, enter your router serial number into the password and click ok. It the next screen that comes up we want a copy of, just do a copy and paste with your cursor, but delete the lines at 1.3 and 3.3 when you paste it into a post.
20-08-2014 9:12 PM
Technicolor Gateway
Broadband Connection
Toolbox
Home Network
Help
Home
Technicolor Gateway
Technicolor Gateway
Information
Product Name: TG582n
Software Release: 8.4.4.J
Broadband Connection OK
Internet: Connected
Toolbox
Toolbox
Game & Application Sharing
Firewall: Disabled
Parental Control
Home Network
Home Network
WLAN Interface Wireless: Jills-iphone
Jills-iPhone
Jills-iPad
Lynne-iphone
Jills-iPad
Ethernet Interface Ethernet: MICKZYYY
Micks-PC
BlackAlpha
This is all i get?
20-08-2014 9:21 PM
20-08-2014 11:10 PM
21-08-2014 11:50 AM
21-08-2014 2:18 PM
21-08-2014 3:43 PM
Could you possibly supply us with the serial number of the router you are using (By PM to AdamC)? It should begin with CP..
21-08-2014 3:47 PM
To be is to do - Kant
do be do be do - Sinatra
21-08-2014 6:19 PM
21-08-2014 8:55 PM
see Luke's reply #29, he didn't think that it was advisable right now because of the drops in connection. He thought it may make things worse.
BUT now matters could get complicated. You have never mentioned that you have two modem/routers. One was supplied by Plusnet, where did the other one come from?
We are talking about the TG582n - The one we are interested in, is the one that you have on-line at the moment (we assume) that you posted the information about yesterday in reply #33. That is the one that needs to be on-line, the one that says Software Release 8.4.4.J as in your reply #33 above. Also does it say Plusnet on the outside of it?
BUT you need to send that PM as soon as possible to "Adam C" another Plusnet member of staff. It's the serial number of your TG582n and it begins with the letters CP....
It's the one you use as a password to log into the modem/router. It's marked on the label on the modem/router as well.
You need to leave that modem/router online and switched on and not change it.
What will then happen, and what's been proposed is that you will be automatically sent from Plusnet's end, a Firmware update direct to the modem/router. This should be the cure for the current problem. As soon as that is in hand, they should be able to do the order for turning off Interleaving.
When that is done we should be able to get your Gaming sorted as well.
Have you understood all that, if not ask the questions.
21-08-2014 8:56 PM
21-08-2014 11:12 PM
21-08-2014 11:19 PM
Just send that serial number to "Adam C".
Is that OK?
