internet is appauling now
- internet is appauling now
Re: internet is appauling now
13-08-2014 6:20 PM
Looking at the errors in the stats you have provided it looks like interleaving is actually off, as before it was applied to the line my router showed no errors, but as soon as it was applied the stats showed a lot of errors, but since interleaving stabilised the line that was all BT & PlusNet would do to help solve the issue. Highly frustrating but as soon as we get bad weather from the south east the line gets a lot worse and by the time anyone gets round to looking at the problem its usually starting to fix itself
13-08-2014 6:25 PM
13-08-2014 8:31 PM
14-08-2014 10:43 AM
Quote from: MickHowes1 yes i can see my exchange from my window xD, hence why i dont understand how im disconnecting so many times when im so close to my exchange haha, its weird as hell, and luke i sent the router stats etc on this post, i dont know if thats what u wanted the login details for but hopefulyl it was, if not comment back what u need and i will do it when i get home from work tommorow/
I've sent you a PM. I'm out of the office tomorrow but should be able to check on Saturday.
14-08-2014 5:56 PM
14-08-2014 10:31 PM
I'm glad you got Luke's PM OK and that at least is sorted. But don't forget please, as per my reply #14
Can you click on http://192.168.1.254/landing.lp and copy and paste that here similar to what you did for the stats before BUT delete the MAC address at 1.3 and the IP address at 3.3 from the pasted bit.
Are you using wireless to connect your Xbox and Computer or Ethernet cable?
This information may be very significant..
16-08-2014 8:34 AM
16-08-2014 2:08 PM
The connection seems to be absolutely fine now. However, Interleaving still appears to be on the line which vexes me. I will escalate with BT on Monday.
<img src="http://community.plus.net/visualradius/generated/image14081944292631.png"/>
16-08-2014 3:51 PM
Mick, see my reply #20 above, that could still be useful information for future reference.
16-08-2014 5:42 PM
16-08-2014 5:53 PM
16-08-2014 7:08 PM
Quote from: Anotherone Hmm, interesting. Now I should have picked this up from the previous stats, but noticed from the above, the sync is at 8128 and I thought it wasn't supposed to be possible to get above 8096 on an interleaved line especially with that make of line card (but I may have done so myself, I'll look back through my notes), but it may depend on the Interleaving depth which we can't tell at the user end without telnetting in, but that may be far to complicated for Mick to be bothered with.
It is possible to sync at 8128 with an interleaving depth of 64 in combination with TSTC DSLAM vendor.
16-08-2014 8:03 PM
Mick, for the third time, if you don't provide information when asked it will take longer to find out what is going on. Will you please do the following-
19-08-2014 10:00 PM
Also Can u explain why im still on interleaved? as its been like maybe a month or so now? surely there is no possible reason for it not to be done by now, they could have manually got an engineer to the exchange to do it by now
20-08-2014 11:28 AM
Considering that your main complaint seems to be regarding the disconnections I don't think it's wise to remove interleaving. It would be helpful for all of us if you could supply the information Anotherone has requested.
