internet is appauling now
- internet is appauling now
- « Previous
- Next »
Re: internet is appauling now
31-08-2014 8:59 PM
The OR van would have had nothing to do with it. It will be the firmware upgrade. The order for Interleaving off, as you can see above, was placed on Saturday. I believe to stand any chance of that working without escalation, an SNR Reset is done first which will also restart the line without Interleaving.
So you may like to check your Ping times, it will be interesting to see if that has worked.
PS. I hope you have your Firewall turned on.
Message 61 of 65
(587 Views)
01-09-2014 7:29 PM
yes my firewall is turned on. and my ping times are the same. and if the order was pout through on Saturday it wouldn't be turned off till tomorrow at the earliest anyway
Message 62 of 65
(587 Views)
02-09-2014 9:26 AM
Hi Mick, just to let you know I'm still keeping an eye on this and if you can check things over the next few days and see how things are.
Cheers,
Dan
Cheers,
Dan
Message 63 of 65
(587 Views)
02-09-2014 1:31 PM
Cheers dan, its going fine at the minute, however i still havent got the interleaving removed from my line.
Message 64 of 65
(587 Views)
02-09-2014 2:57 PM
Don't worry Mick, I'm still on the case.
Message 65 of 65
(587 Views)
- « Previous
- Next »
