disconnections on the test socket
- disconnections on the test socket
16-12-2013 2:40 PM
My normal broadband line hasn't disconnected once yet but I plugged my broadband cable into the test socket to see if there was any speed difference and then my broadband disconnected like 3 or 4 times, I did everything correct by the guide I read and repeated it the same way each time but still disconnected, is their a reason for this?
Message 1 of 6
(791 Views)
5 REPLIES 5
Re: disconnections on the test socket
16-12-2013 2:44 PM
A thought
If your normal socket is a filtered faceplate then you plugged into the test socket is via a filter - is it possible that it is dodgy
Message 2 of 6
(558 Views)
16-12-2013 2:48 PM
I plugged the cable in with the filter connected to it
Message 3 of 6
(558 Views)
16-12-2013 3:46 PM
What could cause this?
Message 4 of 6
(558 Views)
16-12-2013 3:53 PM
Just possible that it's dirty or slightly corroded contacts in the test socket, may have been OK with the (undisturbed) faceplate connection?
Plugging and unplugging a few times might just be enough to 'wipe' the contacts. Might be worth looking into the test socket with a torch to check that the contacts (fine, gold-coloured springy strips) look clean and properly aligned - evenly spaced and all the same 'height' from the edge of the aperture - it can be possible to clean the contacts but only with great care using a cotton bud and isopropyl alcohol, don't attempt this if you're not 100% confident. Also check the appearance of the contacts you're plugging into the socket (clean smooth and shiny).
Call me 'w23'
Message 5 of 6
(558 Views)
16-12-2013 3:55 PM
Quote What could cause this?
I understand you might be keen to rule out any problems but unfortunately we can't state the precise reasons for a short stint of disconnections such as that. We'd usually be able to shed more light on such a problem as part of an ongoing investigation.
I hope that doesn't come across as sounding negative, I just wanted to set an expectation.
Adam
Message 6 of 6
(558 Views)
