bad evening connection
- Re: bad evening connection
17-01-2012 11:55 AM
17-01-2012 12:27 PM
I've just ran some checks, there are a lot of errors. When was the last time you changed the filter?
Jojo
17-01-2012 2:54 PM
18-01-2012 5:45 AM
18-01-2012 2:16 PM
18-01-2012 5:17 PM
basically it runs across one side of room to the master socket and the router is at the master socket, the cable goes round the chimney breast and along the skirting board to the router on the floor behind the TV , which sits on a stand 500 mm above the floor , no dvd player or sat reciver near , and the Tv is on during the day so i couldnt see that causing any problems night only ?
am just hoping that soon BT enable the FTTC box outside my house March they say
19-01-2012 6:48 PM
21-01-2012 9:09 AM
this is what i get with the new filter JoJo
23-01-2012 10:11 AM
I'm seeing 19788K sync with a few errors and 3dB SNR. Maybe this needs setting higher. What issues are you having at the moment?
Jojo
23-01-2012 10:20 PM
i have miniaml progs running windows services tweeked unneeded ones dissabled , i run C cleaner at least once a week , Malwarebytes also , and i have MS security essentials & firewall running updated all drivers to latest win7 64 .
any chance of finding out a better date for FTTC from BT rather that just sometime in march
23-01-2012 11:13 PM
BB stats are exactly the same as in the day time / early evening but as soon as 10 PM comes I struggle to hit anything.
example, same server, same map (seine crossing) 9 PM (joined halfway through the map) 35 kills 8 deaths......... after 10 PM playing the full map 19 kills 23 deaths.
I am on the old premium package where gaming is @ line speed all the time so I can't work it out. It's been like this for years.
24-01-2012 7:29 AM
the wierd thing is its not every night , but 3 - 4 nights a week , could it be weather related ?
24-01-2012 9:37 AM
I would suggest popping a ticket in with what game it is and a wireshark capture when it's being funky, we can then check that it's prioritised correctly.
Jojo
24-01-2012 9:53 AM
http://community.plus.net/forum/index.php/topic,101240.0.html,
i will raise a ticket about the game , BF3 bit its not on list but shold be ok as similar to BF2 / BC2
24-01-2012 1:12 PM
Jojo
