Wireless issues with Thomson v8 (after firmware upgrade) Updated.
- Re: Wireless issues with Thomson v8 (after firmwar...
Re: Wireless issues with Thomson v8 (after firmware upgrade) Updated.
05-03-2011 1:08 PM
Product Name: TG585 v8
Software Release: 8.2.7.7
Failure message attached
05-03-2011 4:54 PM
Were you conducting the upgrade wired or wireless?
Jojo
05-03-2011 4:58 PM
05-03-2011 5:03 PM
To be honest I didn't, either, until my first attempt with a 585v7 failed.
I've never had to disable AV or firewall using XPPro laptop with ethernet connection and both 585v8 upgrades have gone smoothly.
07-03-2011 10:00 AM
Quote from: Joanne Hi PamWest,
Jojo
I can't beleive this would work wirelessly, so sorry the answer is wired
07-03-2011 11:26 AM
As you are having difficulty upgrading the router firmware I will pass this over to be upgraded from our end for you.
Jojo
07-03-2011 12:38 PM
Jojo
Thanks for that - do you know WHEN you will be doing this as I'd hate to be in a Heroic instance and find my router has decided to reboot itself ....... LOL
07-03-2011 2:00 PM
08-03-2011 11:33 AM
Any ideas as to when it may get done plz
08-03-2011 11:38 AM
I'll find out what's happening for you.
Jojo
08-03-2011 12:28 PM
Great job guys, thank you again
08-03-2011 12:42 PM
Great to hear. Thanks for letting me know.
Jojo
11-03-2011 10:59 AM
I'm experiencing this wifi upload speed issue with a client this week, the firmware update 8.2.7.8 (on a v8) hasnt helped.
Wired is results like this 6495 and 370, but the wifi is only around 80 - 100k upload- even with a machine sat right next to the router.
All of their machines are slightly older Macs..
Was there any solutions found please, or do I need to give up and try a different router. I presume its something to do with the router as they've only just changed from a BT home hub to the thompson from plusnet.
Thanks.
Simon
11-03-2011 2:41 PM
You just have to change the BT Home Hub user name in the Settings to the PlusNet username/password, and Robert's your paternal parent's sibling.
11-03-2011 3:15 PM
Unfortunately it's still something we're unable to replicate and is continuing to frustrate us for that reason.
Jojo
