Wireless issues with Thomson v8 (after firmware upgrade) Updated.
- Wireless issues with Thomson v8 (after firmware up...
- « Previous
- Next »
Re: Wireless issues with Thomson v8 (after firmware upgrade) Updated.
10-11-2012 10:52 AM
Interface Type: 802.11b/g
I also tried the other interfaces like 'g' only, 'legacy b/g', but results are similar.
Also I agree with w23 on that this doesn't appear to be a problem with Dell. I checked on an Acer, relatively new, with Win 7 as well and results and experience are similar.
12-11-2012 12:26 PM
Quote from: passingcloud I just realised that I might have been facing the same wireless upload speed slow problem. I did notice this thread some months back and did the firmware upgrade, I think ...
Yeah, looks like you're using the 8.2.7.8 firmware. Are you able to get hold of another router to test. If you can, and you find the problem is no longer evident, then I can probably arrange for a 582N to sent out to replace the 585v8.
By the way, whilst looking at our account I noticed your upload is capped at 448kbps do I've placed an order to uncap it (should complete tomorrow at some point).
12-11-2012 9:55 PM
13-11-2012 12:04 PM
14-11-2012 11:02 PM
15-11-2012 2:51 PM
02-08-2013 9:36 PM
Device : Desktop
Make : iMac 21.5 inch
OS : OS X 10.8.4
Issue : low upload speed
05-08-2013 11:18 AM
- « Previous
- Next »
