Will my Sync return to it's previous level at any point.
- Re: Will my Sync return to it's previous level at ...
Re: Will my Sync return to it's previous level at any point.
25-06-2014 9:51 PM
26-06-2014 9:14 AM
I think BTO should give the option of no DLM. I don't know why my line went the way it did - nothing on the charts to show anything that would cause it. and with BT now being on watchdog it seems this DLM is just no good.
Still, as a user - what do I know.
30-06-2014 9:25 AM
When DLM sees errors on your line, it takes action to ensure you have a stable service. There might be errors on your line, which are not apparent to you - either by affecting your internet performance or voice service. DLM acts on the side of caution, providing stability over speed. Some people on here disagree with that, but it looks like Openreach is working with CPs to ensure there are more DLM profiles available to meet all user needs.
30-06-2014 2:26 PM
Then I can be sure.
30-06-2014 2:36 PM
17-07-2014 2:00 PM
17-07-2014 2:27 PM
17-07-2014 2:45 PM
29-07-2014 12:38 PM
29-07-2014 7:13 PM
29-07-2014 8:45 PM
Forgot to say OR engineer was fab. He not only let me choose which Modem I wanted ( so I chose a HG612) but he also took me to the NGA to have a look,. There are 24 on this one
30-07-2014 9:31 AM
30-07-2014 9:40 AM
30-07-2014 10:40 AM
30-07-2014 10:48 AM
The House Moves Team will check over everything when they next pick your ticket up anyhow, just to double check.
