Will my Sync return to it's previous level at any point.
- Re: Will my Sync return to it's previous level at ...
Re: Will my Sync return to it's previous level at any point.
08-06-2014 3:48 PM
They have sent the fault back to BTO for the third time now, lets see if anything different comes of this I have my doubts.
10-06-2014 1:39 PM
He then said he was going to the exchange and would contact me when done that is the last i have heard from him and that was about 4 hours ago, either he just made an excuse and left or he went to the exchange and found something wrong that has taken him so far 4 hours to solve i don't know either way It seems i still have a battery fault or maybe not who knows, and profiles that DLM is lowering ( BTW IP down to 57Mb ) due to the Modem disconnections all the engineers have done.
11-06-2014 3:05 PM
worse thing is i'm having a new kitchen fitted tomorrow and such power will be off for most of the morning as the electrician fits the plug sockets etc so that's not going to do my profiles and sync any good.
can i ask DTC if engineers have come to me and disconnected the modem to do tests does that qualify for a DLM reset or does it have to be actual work done as in replacing parts at the cab etc, it seems a little unfair to have my profiles drop as much as they have due to the number of engineer tests and not be able to get it back until DLM chooses to which could be weeks maybe even not at all , If it is possible can it be done on Friday after the kitchen refit thanks.
Edit.. actually if it is possible for the DLM reset it might be better to wait and see how the outcome of the fault progresses first it may end up with more visits
11-06-2014 4:37 PM
I hope yours gets sorted. I'm not holding out much hope on mine.
At Install
http://www.speedtest.net/my-result/3527808526
Just now.
I now officially pay around £16 a month more and get less than someone on 60mbps cable. Why did I bother 😕
11-06-2014 5:05 PM
Have you raised a fault on this to see what the initial run of tests throw back?
Taking a look here your line does show speed estimates of 79mbps to 41mbps and you're currently achieving the lower end of the "clean" estimates at 59mbps.
It may not return anything useful but I guess it's worth a look if you think the line is capable of the continued higher speeds
Thanks,
Adam C
11-06-2014 5:08 PM
Quote from: Terranova667 Edit.. actually if it is possible for the DLM reset it might be better to wait and see how the outcome of the fault progresses first it may end up with more visits
I think we should be able to look at a DLM reset for you if the see major impact on your speeds as part of the fault resolution
11-06-2014 6:11 PM
Hey Adam, Nice to see you again.
I've cancelled my fault because I've just been told I am moving in a month or so. No point as it will be another NGA 10 miles away
Cheers anyway
12-06-2014 2:24 PM
Any way i haven't heard anything back from support yet in regards to the last engineer visit so i have no clue if there is still a fault or not ?
12-06-2014 3:08 PM
Your sync speed still isn't restricted by the DLM, so it is a case of seeing if that adjusts on a future resync.
12-06-2014 4:25 PM
this is what i'm currently getting with a speed test 7Mb loss compared to what I use to get when everything was well as shown in my sig
<a href="http://www.speedtest.net/my-result/3559294916"><img src="http://www.speedtest.net/result/3559294916.png" /></a>
12-06-2014 4:54 PM
Just running an end to end test of your line shows a sync speed of 59.8 at present. To work out your IP profile it would be 59.8*0.967, that gives us the Plusnet profile speed you have set on your account at present which is 57800 so all looks as it should do based on your sync speed.
Now that the fault has cleared we'll have to see where the sync ends up however the DLM isn't affecting this at present so all looks good from that perspective. It may be that reconnection from yourself will alter the sync speed or possibly DLM if this sees that the line is capable of more. We'll just have to see how it goes
Thanks,
Adam C
12-06-2014 5:28 PM
13-06-2014 9:21 AM
13-06-2014 2:34 PM
13-06-2014 2:42 PM
Speed test today
<a href="http://www.speedtest.net/my-result/3561212587"><img src="http://www.speedtest.net/result/3561212587.png" /></a>
