What type of cable connects between the BT modem and the plusnet router
AbdulR
I'm planing to replace the supplied cable with a 1m STP cat6 cable. to prevent possible inference due to power supplies. Just need an idea of what cables in use.
Plusnet Staff
Plusnet Staff
Fixes: 5
Re: What type of cable connects between the BT modem and the plusnet router
The cable that's used to connect the Openreach Modem to your Plusnet router is an Ethernet Cable.
I hope that helps.
Chris Pettitt
Cloud Environments Engineer
AbdulR
hi Chris, i just wanted to know if it was a straight through/ rollover etc. saves me buying the wrong cable
jim:quote
I would say a standard straight through from memory - if you have the cable that came with it just see if it has a small band with a "x" on it for crossover.
I'm using a straight through for my BT to TP-Link.
pwatson
It's a normally wired (ie not crossover) cable but you're wasting your money!
Changing this cable will have zero affect on your broadband performance.
