What is the best time to resync
- Re: What is the best time to resync
24-05-2012 2:25 PM
On another note, I have just noticed there is white paint outside my next door neighbours house, it is marking out a square about the size of a green cabinet. Does anybody know how long from the paint going down to me getting fibre ::).
Thanks for reading.
24-05-2012 2:36 PM
24-05-2012 2:49 PM
24-05-2012 4:17 PM
Type Interleave Path
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 10483 1227
Noise Margin 6 6
Output power(dBm) 12 20
Attenuation(dB) 29 16
All I can get unfortunately from The Belkin
Thanks Gus, unfortunately though sometimes I just turn off my router without disconnecting so BT sees it as a lost sync and it comes back higher then if I disconnect in the router page so BT doesn't see it as a lost connection. I guess with this router, or my connection it just depends what mood my router is in :-\.
24-05-2012 4:22 PM
24-05-2012 4:30 PM
You upped my Plusnet IP to match my sync of 12500+ a couple of weeks back but I noticed today with the sync dropping and not going above 10500, the plusnet IP has dropped back down to 10.7.
25-05-2012 11:56 AM
Uptime:0 days, 0:53:38
DSL Type:
G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]:1,191 / 9,943
Data Transferred (Sent/Received) [kB/kB]:0.00 / 0.00
Output Power (Up/Down) [dBm]:12.5 / 0.0
Line Attenuation (Up/Down) [dB]:17.5 / 32.5
SN Margin (Up/Down) [dB]:6.0 / 6.5
Vendor ID (Local/Remote):TMMB / IFTN
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):0
Error Seconds (Local/Remote):0 / 0
FEC Errors (Up/Down):15 / 0
CRC Errors (Up/Down):15 / 72
HEC Errors (Up/Down):31 / 58
Edit : I just did a refresh and notice what has happened to the FEC,CRC and HEC UP errors, is this normal ?
Uptime:0 days, 0:58:57
DSL Type:G.992.5 annex A
SN Margin (Up/Down) [dB]:5.5 / 6.5
FEC Errors (Up/Down):0 / 0
CRC Errors (Up/Down):0 / 75
HEC Errors (Up/Down):0 / 61
25-05-2012 3:22 PM
25-05-2012 3:43 PM
Quote I know you've had this issue for a while, and to be honest, I'm stumped
A few years now Jojo.
Quote Sounds like that drop wire might have added the extra attenuation
Sorry Jojo I should have mentioned that the drop wire was put in over 8 months ago.
The attenuation only goes up when I put the Thomson router on Jojo, when I switch back to the Belkin the attenuation drops back down to 29. Same as my Ping, it is 5 m/s when the Belkin is on but it goes up to 15m/s when the Thomson is on. If I can handle having the Thomson on for more than a day, I might try and leave it for a week and see what happens. I first got the Thomson when I was switched to 21CN my ping in PC games went up to 999 which is why I couldn't use the Thomson and had to buy the Belkin.
Edit, I have tried about 10 differnt filters, 10 different ways to wire up the phone and router, 2 different routers and nothing seems to fix it, and BT wonder why I tell them to stop harrasing me when they phone up at 9 o'clock on a Friday night asking me to switch.
25-05-2012 4:15 PM
25-05-2012 6:12 PM
Quote Don't bank on it but I'll put my feelers out and see if I can get my hands on one for you
No worries, I will leave it with you.
26-05-2012 10:50 AM
Uptime:0 days, 23:45:57
SN Margin (Up/Down) [dB]:6.0 / 6.0
CRC Errors (Up/Down):0 / 1,203
HEC Errors (Up/Down):0 / 972
26-05-2012 12:58 PM
Have a read of this post I've just made on another thread.
26-05-2012 3:27 PM
I read your post, and I am going to put my Belkin back on now because the thomson is making my online gaming lag. Upnp is off but it makes no difference.
26-05-2012 3:49 PM
Status SHOWTIME
Downstream Upstream
Data rate(Kbps) 10745 1171
Noise Margin 6 6
