What is the best time to resync
- What is the best time to resync
Re: What is the best time to resync
26-05-2012 3:59 PM
Ah. now that sync speed is better, but your line is still under performing for some reason. I'll post some ideas later.
Run the BT speedtester, to check your current IP profile.
I've added an edit to that post I referred you to, about clicking Connect may be necessary after powering up, but another that could be useful to you is using the Disconnect/Connect (without a power down) to Gateway hop if you are having problems with ping times and another Gateway may be better.
29-05-2012 2:52 PM
Internet browsing seems to be a lot quicker with the technicolour though which is good, I will have a go at gaming tonight and see how it goes.
One thing that bugs me about the Technicolour though is there is no place to save your log in details when you open up 192.168.1.254. So you have to put them in everytime
Uptime:0 days, 3:48:47
DSL Type:ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]:1.171 / 10.747
Data Transferred (Sent/Received) [MB/MB]: 9,47 / 151,42
Output Power (Up/Down) [dBm]:12,6 / 0,0
Line Attenuation (Up/Down) [dB]:18,2 / 33,5
SN Margin (Up/Down) [dB]:6,0 / 5,7
System Vendor ID (Local/Remote):TMMB / ----
Chipset Vendor ID (Local/Remote):BDCM / IFTN
Loss of Framing (Local/Remote):9 / 0
Loss of Signal (Local/Remote):1 / 0
Loss of Power (Local/Remote):0 / 0
Loss of Link (Remote):-
Error Seconds (Local/Remote):186 / 0
FEC Errors (Up/Down):0 / 0
CRC Errors (Up/Down):21 / 197
HEC Errors (Up/Down):7 / 862
29-05-2012 4:57 PM
30-05-2012 7:42 AM
I presume you know all about the bell-wire and it's associated problems and that's sorted?
30-05-2012 3:22 PM
Anotherone, I have looked back through some of my line stats and I do have one from the Belkin @ 12500+ sync with a DL noise margin of 4, I remember I used to get quite a few disconnects as the DL noise went down to 2 of a night time but it seems pretty stable for the last year sitting at both up and down noise of 5, 6 and sometimes 7.
I removed the bell wire a few years back but thanks for the reminder. At the moment (BT fitted me a new face plate for the master socket when they put the drop wire in about 6 months ago) I have one extension cable attached behind the face plate with the 2 wires on number 2 and 5. This goes to a normal extension box which has a filter then the ADSL cable to my base phone. I have another 2 phones (just needing power) that run off the base phone., BT graphite trio. I have a filter in the master socket face plate with a 2 metre adsl cable going to my router at the bottom of the stairs. I then have a 10 metre CAT 6 cable going from the router to my computer.
I have a question, is it better to have the setup like I have with the 2 bare extension wires going straight into the master socket behind the face plate, or is it better to have an extension cable with a RJ45 on the end and have this going into the filter that comes out of the face plate.
30-05-2012 3:39 PM
Don't use telephone extension cables (except perhaps between a corded phone and it's filter) never between the wall socket and a filter, they are a source of interference pickup because they aren't twisted pair and generally have all 4 wires connected (ie inc.the bell wire).
As long as the cable from the Master socket faceplate to any extension sockets is to spec.CW1308 as used by BT you shouldn't have a problem if only the 'Blue/white trace' and 'White/blue trace' wires are used and connected to terminals 2 & 5.
Never use filters that look like solid splitter blocks, they are inferior quality. Always use a quality "rat's-tail" type ie. the type that's come with your 582n.
HTH.
31-05-2012 3:30 PM
Jojo, I had a few rounds last night on BF3 and even though my web browsing seems quicker, there was no noticable difference in gaming. The only difference noticable is the technicolour has a higher ping than the Belkin. Example, All my favourite servers are saved because they have a 12 ping, now though they all have a 15 ping. No big deal but that is the only difference I can see.
The technicolour, like my Belkin seems to be stable with the only disconnects being me rebooting trying to get back up to 12500+ sync from the10700 I think it is at the moment.
06-06-2012 2:28 PM
Uptime:0 days, 0:06:16
Bandwidth (Up/Down) [kbps/kbps]:1.159 / 10.747
Data Transferred (Sent/Received) [kB/MB]:561,41 / 3,68
Output Power (Up/Down) [dBm]:12,8 / 0,0
Line Attenuation (Up/Down) [dB]:18,0 / 33,0
SN Margin (Up/Down) [dB]:6,0 / 5,9
Loss of Framing (Local/Remote):0 / 0
Loss of Signal (Local/Remote):0 / 0
Error Seconds (Local/Remote):6 / 0
CRC Errors (Up/Down):1 / 6
HEC Errors (Up/Down):0 / 29
06-06-2012 4:51 PM
06-06-2012 5:22 PM
Although the Technicolour has dropped form 33.5 to 33.0
06-06-2012 9:39 PM
07-06-2012 10:23 AM
07-06-2012 8:36 PM
24-06-2012 11:19 AM
27-06-2012 10:11 AM
Thanks.
