VDSL wiring
- Re: VDSL wiring
VDSL wiring
19-10-2013 4:33 PM
Is there likely to be any discernible difference in performance between the following two setups:
i) NTE5 > supplied lead to BTOR modem >12 metres of cat5E > billion 7800n
ii) NTE5 > 12 metres of cat5E > BTOR modem > billion 7800n
Message 1 of 6
(878 Views)
5 REPLIES 5
Re: VDSL wiring
19-10-2013 4:41 PM
i) This is the better option and the speed will be (potentially) better with this. Whether it will make any difference, I cannot say. However, if you can, choose option i.
Message 2 of 6
(455 Views)
Re: VDSL wiring
19-10-2013 5:32 PM
Many thanks for the quick response. If BTOR supply their optional extension kit where does that fit in?
Message 3 of 6
(455 Views)
Re: VDSL wiring
19-10-2013 5:49 PM
OR will do option i.
Message 4 of 6
(455 Views)
Re: VDSL wiring
19-10-2013 8:41 PM
May I say in (ii) Its not CAT5E cable from NTE5 its a standard RJ11 cabling not ethernet.
Ex Plusnet Fibre customer. Sky Ultrafast (G.Fast) Customer using a Sky Hub 4.2. If you wish to say thanks, please click the thumbs up
Message 5 of 6
(455 Views)
Re: VDSL wiring
19-10-2013 10:18 PM
I have an existing 12 metres run of cat5E from near to the NTE5 to another NTE5 type socket adjacent to the current modem's position so I was thinking of just linking the second NTE5 and the modem together using an RJ11 lead.
Message 6 of 6
(455 Views)
