Channel 4
rongtw
Fixes: 12
Channel 4
anyone had problems streaming channel 4 live ?
i get this everytime
NorthEasterner
Re: Channel 4
Can't be bothered to sign up.  But BBC iPlayer and ITV live players work.
Ex Plusnet Fibre customer. BT Infinity Customer using a BT Smart Hub. If you wish to say thanks, please click the thumbs up Thumbs Up
Fixes: 10
Re: Channel 4
I get the same on channel 4 - but 4 Music plays OK!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
rongtw
Fixes: 12
Re: Channel 4
i used to be able to watch on TVcatchup.com , but now it just redirects to Channel4  Tongue
Re: Channel 4
@rongtw - same thing here. Other TV catch-up services play just fine.
rongtw
Fixes: 12
Re: Channel 4
So it must be Channel 4 problem  Embarrassed
Re: Channel 4
Actually, I've sussed this - using Firefox 24, doesn't work. Using IE11, does work. Found that by disabling AdBlock+ in Firefox, stream worked. You can re-enable AdBlock+ once the initial advert starts, and the stream will continue to play.
rongtw
Fixes: 12
Re: Channel 4
Kiss  nice one Jaggies works for me now Disable adblock  Wink
Re: Channel 4
Actually, you can just disable it for the Channel 4 page from the Tools menu in Firefox - Tools-> Adblock Plus-> Disable on this page only. Saves you from having to remember to do it every time.
I guess it was only a matter of time before some catch-up TV site figured out how to stop viewers dodging adverts, although this appears to be the only one so far. I wonder if Adblock Plus will be updated to suit - I suspect the issue will need to be reported to them before that happens...
rongtw
Fixes: 12
Re: Channel 4
yup jaggies  Wink did that allow for this page only ,but i hate to have all the adverts
