Useless Plusnet Now ??
stathe
Here I am with no proper internet speed point five E mail doesnt work now and if it does unreliable  How do I proceed I need to keep my plusnet email address Do you do satelite based internet for remote people
98 REPLIES 98
stathe
Re: Useless Plusnet Now ??
Just switched off and on and some improvemerty but still prety dud and unreliable
Fixes: 392
@stathe As I replied on another topic, NO  - plusnet do not do sattelite.
stathe
not bothered about compensation or contracts I just want it to work and need to keep my plusnet address
stathe
Would like cheap satellite and to keep my PlusNet address Any ideas for an 86 year old light user
stathe
Still pretty useless in my area  When I switch on in the morning the connection speed is abysmal .5 or so (router is on all the time ) I then need to switch off the router , for a few minutes , to get an acceptable ( not really ) speed  Do Plusnet provide  a service with mobile phone
Smith7
All Star
Good afternoon,
Satellite broadband is very expensive like satellite mobile phone
Is the mobile phone signal in your area any good see below and put in your address to find the best supplier for your address
If so why not use mobile broadband by using your phone as a hotspot it's called tethering or purchase an *UNLOCKED* ALCATEL EE Osprey 2 4G   to use on any network I use one at the caravan and it's excellent  and very easy to use
Any questions just ask
https://checker.ofcom.org.uk/en-gb/mobile-coverage
stathe
So how do I set about this my Vodafone signal seems good  Do I stay with PlusNet and how about my email as I need to keep my email address  as it is important to me
@stathe
Have you checked to see if any faster services are available to you recently?
https://www.broadbandchecker.btwholesale.com/#/ADSL You never know !
Post your results here if you're not sure, be sure you hide you phone number.
You can keep your email address if required but you have to request this with PlusNet on the phone 0800 5871942
Dan.
Smith7
All Star
If you leave PN and wish to keep the email address you have to tell them when you leave I think there used to be a charge but now it's free but you have to tell them at the time of leaving
I your speeds are as low as you say are they well below the Minimum Guaranteed Download's if so you should be able to leave for free
To use your mobile phone as a hotspot
To turn your Android phone into a hotspot, go to Settings, then Mobile Hotspot & Tethering. Tap on Mobile Hotspot to turn it on, set the name of your network and set a password. You connect a computer or tablet to your phone's Wi-Fi hotspot just as you would connect to any other Wi-Fi network
My phone automatically gives the name and password to use
I have just tested the speeds of  my PN mobile
Download 24.99 Mbs
Upload      8.6    Mbs
Good luck
pvmb
Seasoned Champion
Fixes: 17
I notice you titled this thread Useless Plusnet Now ?
Have you been able to establish whether your broadband problems are caused by faults on your landline or are inherent? That is, due to your being a great distance from your exchange, or inherently low quality phone lines?
So is this a new problem or has it always been present?
stathe
Long way from the exchange and always a problem , though sometimes worse and even  "Worser" The strange thing is I complain and it improves slightly to acceptable in the circumstances
Smith7
All Star
Hi again
Time to leave then
How you tried to tether your phone using the Vodafone signal what results do you get
Just spoken to my daughter she says/thinks Apple devices do not support tethering  Android  do
Talkmobile which is owned by Vodafone and therefore use their signal have some very good data deals
TheMightyAJ
Fixes: 126
Hi @stathe,
I'm really sorry to hear that you're experiencing issues with the connection. I've had a look over the account this evening and I can see that unfortunately the estimated line speeds are quite low. With that having been said, my line test that I've run shows the downstream sync speed to be coming in at a rate of 2.3Mbps, which is close to the upper limit of the estimated speeds. As this is the case, I'd just like to ask what speeds you're getting when you run a speedtest from your side of things and whether or not you're connecting via Wi-Fi or Ethernet cable?
 Alex H
stathe
http://mybroadbandspeed.speedtestcustom.com/result/a3432710-718c-11ec-82c2-6d6580abc7a6
This is much better now ,but always is improved when I complain and I have to switch on and off to get a half decent result
This is by wire on my desk top and wi fi around the house Speeds above 1.5 enable me to use my bank and church connection and see my family on Meet
