Useless Plusnet Now ??
stathe
Re: Useless Plusnet Now ??
yesterday
stathe
This morning it really is a lot better and I haven't switched on and off     Thank you  27th JAN MID DAY
Fixes: 243
An updated view of the router stats and another BT Wholesale speed test would be useful benchmarks please.  Your perception of "better" seems a little at odds with the metrics you have posted previously.  No change to data speed, whilst Plusnet report an increase in the error rate.
stathe
Port Status TxPkts RxPkts Collisions Tx B/s Rx B/s Up Time
WAN PPPoA 44178889 50922586 0 1577 15126 73:09:37
LAN1 Link down 2429386 1703565 0 7449 1062 73:31:48
LAN2 100M/Full
LAN3 1000M/Full
LAN4 Link down
WLAN b/g/n 145M 9149722 6003191 0 9724 3718 73:31:17
WLAN a/n 300M 458497 223760 0 745 257 73:31:11
ADSL Link Downstream Upstream
Link Rate 2446 Kbps 840 Kbps
Line Attenuation 69.0 dB 43.5 dB
Noise Margin 2.2 dB
stathe
stathe
It seems better for me regardless as I am able to get on  to my bank, speak to my family and see them better than when I first raised the subject
Fixes: 243
That is most odd / intersting - compare that to your speed test of 3rd Jan 2022 before the profile was changed to less stable - https://www.thinkbroadband.com/speedtest/1641211007719937355
Both speed tests show similar results for the x6 concurrent transfer test, but markedly different results for the x1 transfer test. From the Think Broadband speed test FAQ...
"The first download test we run is the tbbx1, where the x1 means we are downloading a single file and thus will show what your performance is like for streaming video. On a good connection with no congestion, traffic management or other issues the speed for a single download should match the multiple download test. The second test uses six downloads at the same time and in situations where Wi-Fi or provider congestion is a factor you may see the second download running a lot faster."
It is somewhat evident that the summary reports point to the x6 results hence the apparent no change in performance from the figures you reported.  I find it odd that the change in x1 transfer speeds might be put down to the slight increase in sync speed, given that the x6 transfers (which are intended to soak the capacity of the link) are identical.
Anyone have any suggestions why x1 might have changed so substantially whilst the x6 test intended to saturate the line remained the same ... which is more or less what would be anticipated of a line running marginally faster with a higher error rate.
stathe
Sorry I don't really  understand this but the whole thing is much "zippier " to me now  Cant remember 2nd Jan
stathe
Dare I tell you that this works quite well with the low   3   noise margin please dont change it
I also have to renew shortly so dont want alterations
