Upload speed
- Re: Upload speed
- « Previous
- 1
- 2
- Next »
Re: Upload speed
16-04-2013 2:57 PM
Quote from: Anotherone @Chris
I noticed the last 2 Network status reports, this being the last made no mention of the Gateway mentioned in the initial report. So did that problem turn out to be more widespread which may account for some of the oddities seen. Nor did the Network usage graphs seem to indicate any significant gateway hopping from that gateway - for what they are worth in their present state
No, the gateway effected was just PTN-AG01, we didn't see anything else being caused issues.
Message 16 of 19
(289 Views)
Re: Upload speed
16-04-2013 4:00 PM
Chris ? so is it possible that my problem was with PN network , rather than mine ?
Message 17 of 19
(289 Views)
Re: Upload speed
16-04-2013 5:17 PM
Not really no, everything is OK although you shouldn't be seeing that amount of fluctuation on you upload.
I'd keep an eye on it and try a PPPoE connection as I previously mentioned so we can try and identify the cause.
Message 18 of 19
(289 Views)
Re: Upload speed
16-04-2013 5:38 PM
Well I find it rather strange that two of us on two totally different types of connection at the time saw exactly the same symptoms!
Message 19 of 19
(289 Views)
- « Previous
- 1
- 2
- Next »
