problem with gateway ptw-ag02 ?
- problem with gateway ptw-ag02 ?
16-04-2013 4:43 PM
I have just jumped on to this gateway and the speed is shocking, usually get a ping of around 59ms and speed of about 6.2mb
bt speed test attached
i switched gateway as the last one i was on i was only getting around 67ms ping and 4mb
Edit : now on gateway gateway ptn-ag03.
Still just over 1mb down on speed what i usually get, could this be down to the network been out of balance due to outage at weekend?
Edit 2: Jumped getaway again gateway pcl-ag02 , run a few more speed tests and the max i can get is 5.2mb
Regards
Mike
Regards
Mike
Message 1 of 2
(729 Views)
1 REPLY 1
Re: problem with gateway ptw-ag02 ?
16-04-2013 5:22 PM
We're not aware of any issues at the moment, I'll flag this up though.
I can't currently check over your line as there's a few issues with the system we use for testing.
Message 2 of 2
(374 Views)
