Upload Speed Dropped to 50k
- Re: Upload Speed Dropped to 50k
12-04-2016 11:18 AM
Seems my upload speed has halved today, are there any known issues ?
Also is it possible to increase my Upload speed in any way ? even at 100k it's a bit tight.
12-04-2016 11:40 AM
Ok, seems a router reset has fixed it, still....what's the fastest upload speed available for ADSL, how much does it cost and how do I activate it ?
Can people still get this uncapping thang ?
12-04-2016 1:38 PM
12-04-2016 6:43 PM
That's a bit tight , no worries I was intending to upgrade to fibre, it's recently been activated in my area.
13-04-2016 11:16 AM
Yeah I have just run some checks for you on the fibre connection and it is available on your line. Depending on what package you select you can look at getting up to 61.5Mbps download and up to 17Mbps upload.
13-04-2016 12:23 PM
That would only be fair if I could pay you 'up to' £xx.xx per month speed dependant.
I'm hesitant into looking into it due to number of bad fibre karma floating around here and the distance I am from the hub.
