Upload Speed Dropped to 50k
ramissin
Seems my upload speed has halved today, are there any known issues ?
Also is it possible to increase my Upload speed in any way ? even at 100k it's a bit tight.
5 REPLIES 5
ramissin
Re: Upload Speed Dropped to 50k
Ok, seems a router reset has fixed it, still....what's the fastest upload speed available for ADSL, how much does it cost and how do I activate it ?
Can people still get this uncapping thang ?
adamwalker
Fixes: 221
Glad to hear that fixed it.
The fastest upload on an ADSL connection that we offer is approximately 1mbps which is what you currently have.
 Adam Walker
ramissin
That's a bit tight , no worries I was intending to upgrade to fibre, it's recently been activated in my area.
BenB
Fixes: 20
Yeah I have just run some checks for you on the fibre connection and it is available on your line. Depending on what package you select you can look at getting up to 61.5Mbps download and up to 17Mbps upload.
ramissin
That would only be fair if I could pay you 'up to' £xx.xx per month speed dependant. Wink
I'm hesitant into looking into it due to number of bad fibre karma floating around here and the distance I am from the hub.
