Unable to turn off firewall
cncalvin
I have been unable to connect to my work VPN (Checkpoint VPN) through my home plusnet network. There have been no issues connecting by tethering my mobile.
I believe the issue may be due to the PlusNet firewall. However, the link to disable to firewall online (http://plus.net/member-centre/broadband/firewall) only brings me to a blank page.
Is there a way to disable the firewall? Thank you
3 REPLIES 3
Fixes: 463
Re: Unable to turn off firewall
@cncalvin   Welcome to the Plusnet Community Fora.
How long have you been a Plusnet customer? I ask as Plusnet stopped providing their broadband firewall a couple of years ago, the argument being that this was a hangover from the dial up days.
pvmb
Seasoned Pro
Fixes: 11
...I assume this applies to newer customers only, as it is still available to me.
Fixes: 463
@pvmb
From memory, if you were using it at the time then it's still available. However, I think that the facility has probably been removed if ir was turned off at the time of the discontinuation.
