Unable to connect to the internet since 5pm today?
- Unable to connect to the internet since 5pm today?
Re: Unable to connect to the internet since 5pm today?
31-01-2015 9:00 AM
Sorry for the late updates last night, I'll feed this back to the team. We've kept an eye on things overnight and can see that people are connecting as normal now.
31-01-2015 2:20 PM
Know that's already been mentioned, but it fooled me as I thought this was a repeat of the recent gateway problems which only required a straightforward click of the connect button when the problems were rectified - just don't ask me how a fault with the radius servers knocks out your internet password from your router!
31-01-2015 2:35 PM
We should have included the following page in the service status posts (it works on a mobile device) as that explains what to do.
www.plus.net/reboot
31-01-2015 2:37 PM
Chris - your link is of course just what you need if you are lucky enough to have an alternative way of reaching the site.
I see that the Home > internet page normally shows the password as a line of asterisks and 'Remember password = Yes', although of course it didn't on this occasion.
31-01-2015 3:04 PM
Quote from: Chris We should have included the following page in the service status posts (it works on a mobile device) as that explains what to do.
www.plus.net/reboot
Chris, I have criticised this short-form link before and it's not been changed, it's hardly a complex thing to do. It should not be called www.plus.net/reboot
1) it's not a reboot, it's a reconnect as described on the page (and a reboot should not be required except in extreme circumstances).
2) The link should be called www.plus.net/reconnect
People that invent incorrectly named links like this frankly give the impression that they don't know the difference between the two things, nor do they appreciate the potential impact on users on long lines that may try a reboot after dark when it's not needed who may do this without reading the link and taking it's name as it implies.>:(
31-01-2015 3:05 PM
https://www.plus.net/home-broadband/router-reconnect/
31-01-2015 3:21 PM
31-01-2015 4:01 PM
I am presumably one of many others who, since about 6pm last night (30th Jan 2015) have had no internet service from PlusNet. This is clearly a big problem and is not resolved.
I have rebooted my router countless times. Following prompts in this thread I have also gone into my Router settings and re-typed my PlusNet account password and saved and again rebooted. Still no joy. All my router settings look fine and dandy. Just no broadband service. This loss of service is now approaching 24hrs which is frankly ridiculous.
What is really going on and what are the resolution options please?
31-01-2015 4:10 PM
Quote What is really going on and what are the resolution options please?
Your line is showing as out of sync, which is not the same as the issue we had last night so it seems like an unfortunate coincidence at the moment unless you've unplugged your router?. Can you confirm which lights are lit on the front of the router and whether they are green or red?
Description
: Line status not in sync
Circuit Sync Status
: Circuit Out of Sync
Can you run through the steps at https://faults.plus.net so this gets reported in to us?
31-01-2015 5:34 PM
Quote Your line is showing as out of sync, which is not the same as the issue we had last night so it seems like an unfortunate coincidence"
lols "unfortunate coincidence" !! Yep right, that must be it. No problems for months and then just when PlusNet suffers a major outage and I can't get any service at just the same time, it must just be an unfortunate coincidence. Right O !
Here's another amazing coincidence. Suddenly, having made a post on this forum, and having visited the PlusNet webpage for "Thinking of cancelling your contract", my modem lights have suddenly come on and my service is restored. It's a miracle !
Summary:
PlusNet service suffered outage and was faulty since at least 6pm on 30th Jan 2015.
PlusNet fail to restore/resync my connection automatically following "resolution" of the outage. Suggests a lack of control of the end-to-end service elements.
Customer (me) has to report the lack of service on my specific line
PlusNet then "tweak" something at their end and hey presto service restored. No changes made at customer end.
Comments:
Good service? - No, following an outage PlusNet should have the ability to reset/resync/restore all affected customers and should know which customers were affected by the outage.
Do PlusNet charge me if I over-use their service (GB limit) - You betcha !
Do PlusNet compensate me when they don't provide the service I pay for ? - Not a chance !
Something is wrong here.
31-01-2015 6:48 PM
Quote from: MrPiffle ..........PlusNet service suffered outage and was faulty since at least 6pm on 30th Jan 2015.
If you had no sync, then you had a problem between your modem/router and the exchange. That sort of issue has absolutely nothing to do with the outage that Plusnet suffered which was a problem that affected the establishment of the PPP Internet session somewhere between the exchange and Plusnet's network (my personal suspicion is this was a failure somewhere on BT's Backhaul).
Because of your understandable cynicism if you don't understand how ADSL works, the way you've phrased your comments doesn't make it clear if your connection is now restored. I suspect that you may have some other issue with your connection which this outage has served to highlight and needs to be addressed. If you have a connection then if you can post the TG582n Full DSL stats (you'll get the login screen first) it may help point a finger at what's going on.
If you still have no connection, then I suggest you follow Chris's advice or ring CSC but this is a peak time and there will be a number of calls queued, so you may have a wait.
31-01-2015 8:01 PM
"30/01/2015 @ 18:16
We're currently aware of a problem resulting in customers being unable to connect to the internet.
This is impacting customers who are attempting to establish new connections and those who have recently disconnected and are now unable to reconnect."
And you say that's not my issue and it's all co-incidence and my issue is no-sync?
So how's my sync now? Does it look ok? If so, how do you think that happened?
My service is fine now. Nothing changed at my end. So "something" changed at your end, and it changed just after I drew attention to my account by posting on this forum and/or visiting the "Thinking of cancelling" webpage. Are we to put this down to magic?
31-01-2015 8:14 PM
31-01-2015 8:22 PM
1) I'm just another user but I have an engineering background .
2) Your lack of SYNC had NOTHING to do with the Outage
3) I can't tell what your sync is which is why I asked you to post your stats
4) This is a community forum where members try to help each other with their problems. It's also a Support channel for Plusnet.
5) If all you want to do is bitch, then I suggest you follow Chris Parr's (Plusnet Staff - that's why he has the logo against his name) earlier advice and raise a ticket and make a complaint to Plusnet.
6) There is unlikely to be any Plusnet staff on here now until Monday.
So yeah, Seriously
31-01-2015 9:04 PM
Quote Your lack of SYNC had NOTHING to do with the Outage
That statement is only relevant if you buy the PlusNet "no sync" line as the cause of the issue. I'm afraid I don't. The timing of my outage coinciding as it did with the wider service outage tells me where the fault truly lay. The sudden restoration of my service after drawing attention to my account also tells me that someone at PlusNet fixed it manually. This isn't the first time PlusNet have "tweaked" something and magically made my service work after I have reported an outage. Time for a change.
